Has anyone had any problems substracting floats? I have the following code: (C166 V4.23 compiler) float dummy, test1, test2; test1 = 1.0e10; test2 = 1.1e10; dummy = test2 - test1; for some reason dummy comes out as 1.000001e9 I've tried declaring them as doubles and get the same result. DS
1.000001e9 is close enough to 1.0e9, isn't it? If it's not for you, move to double. If FLOAT64 directive is not specified, THE C166 COMPILER uses single-precision floating-point arithmetic even if the double keyword is used in the C source file. Go to C166 in the target settings and check the Double-precision Floating Point option. - Mike
Floating-point numbers are by no means EXACT representations of all real numbers. An explanation of how your numbers are represented will probably make more sense. Floating-point numbers are stored according to the IEEE-754 format with a sign bit, exponent, and mantissa. So:
1.0e10 = F9021550x = 1111 1001 0000 0010 0001 0101 0101 0000 MMMM MMMM EMMM MMMM EMMM MMMM SEEE EEEE
1.1e10 = ACE92350x = 1010 1100 1110 1001 0010 0011 0101 0000 MMMM MMMM EMMM MMMM EMMM MMMM SEEE EEEE
Ok fair enough, I'll try and keep it to 6 digits to be safe. I just wonder how my ancient calculator does it as I doubt it is more than a 16bit processor. thanks, DS
The data size of your calculator's processor is irrelevant, the original electronic calculators used 4 bit processors. Most calculators use an internal BCD notation (Binary coded Decimal) to avoid rounding errors caused by conversions from decimal to binary. The tradeoff is speed.
"Most calculators use an internal BCD notation (Binary coded Decimal) to avoid rounding errors" There will always be rounding errors whatever representation you use! Some numbers just can't be written down; eg 1/3. On my casio fx-451, if I reciprocate 9.000000001 and then reciprocate the result I get 9.000000002. You can have hours of fun playing with a calculator to find its little errors like this. Or maybe just get out a little more often... ;-)
