Using the '#message' directive
I'm using uVision 5.14 and this is the error I receive when I try to use the '#message' directive:
error:  #11-D: unrecognized preprocessing directive
#message
Am I missing something?
  • Oh and BTW, my compiler is:
    Armcc.exe V5.05 update 1 (build 106)
  • Where is it claimed that a #message directive is supported ?
  • Are you missing something? That depends on what expectations you have and what reference documentation you based your expectations on.
    But you might consider:
    #define CHARLIE
    #if defined(CHARLIE)
    #warning "Charlie was defined"
    #else
    #error "Charlie is undefined"
    #endif
    "#warning" will give you a warning printout with your message text in the build log but will build the project.
    *** Using Compiler 'V5.05 update 2 (build 169)', folder: 'C:\Keil_v5\ARM\ARMCC\Bin'
    Build target 'Target 1'
    compiling main.c...
    main.c(4): warning:  #1215-D: #warning directive: "Charlie was defined"
    main.c: 1 warning, 0 errors
    linking...
    Program Size: Code=312 RO-data=456 RW-data=0 ZI-data=608
    ".\Objects\test-1768.axf" - 0 Error(s), 2 Warning(s).
    Build Time Elapsed:  00:00:00
    While #error" will produce a compilation error with your text message:
    compiling main.c...
    main.c(7): error:  #35: #error directive: "Charlie is undefined"
    main.c: 0 warnings, 1 error
    ".\Objects\test-1768.axf" - 1 Error(s), 0 Warning(s).
    Target not created.
    Exactly what are your needs for non-warning and non-error messages during the build?
  • My bad, I was looking at Cx51's, not ARM's documentation.
  • What I wanted to use the #message for is a status output indicating build's parameters. The difference between #message and #warning is mainly the intention: warning means there is something potentially wrong; message is more neutral. Plus warning output just takes more space in the build log.
  • I think the language standard only has #error
    I think both #message and #warning are proprietary extensions - which, therefore, may not be supported.
  • I've run into this too. I inherited some arm-none-eabi-gcc code and they have
    #pragma message "message"
