Hi together
I'm testing a STM3240 Bord with a STM32F417IGH6.
I had done the "CMSIS-RTOS Blinky" project successfully on the bord. When I will do the "emWin Example", I have a problem (http://www.keil.com/dd2/st/stm32f407ighx/)
The error message is "Flash Download failed - Could not load file 'C\***\Output\GUIDemo.axf'
What can I do?
thanks for an answer.
Kind of suggests it didn't build/link properly, or it's in a different directory than expected.
W atch for directories off the Desktop, or with spaces in them. Rebuild the project, and look for any error/warnings.
Oh yes, now I see it. I have 449 Errors. All of them are labled by "L9937E: MDK-Pro middleware is not allowed with this license.
That means, I need an other license?
Wouldn't that depend on what license you currently have?
The Evaluation version isn't going to build this. If you've changed the license setting recently make sure to "Rebuild All" to clear any eval settings from the created object files.
Yes I ve changed the license settings recently. Now I have a MDK-ARM Standart Cortex M license.
I tried it without success. I deleted all Files in the "Output" folder.
For licensing issues, you really need to speak to Keil (or your supplier) directly.
