Hello I tried to compile and run arm_fft_bin_example of the cmsis package but there is a problem. The problem is in the arm_bitreversal2.s file that can't be compiled by keil. Is there any workaround and solution? Thanks.
Hello Here is the modified and working code for cortex-m4:
AREA ||.text||, CODE, READONLY, ALIGN=2 THUMB ;/* ;* @brief In-place bit reversal function. ;* @param[in, out] *pSrc points to the in-place buffer of unknown 32-bit data type. ;* @param[in] bitRevLen bit reversal table length ;* @param[in] *pBitRevTab points to bit reversal table. ;* @return none. ;*/ EXPORT arm_bitreversal_32 EXPORT arm_bitreversal_16 arm_bitreversal_32 PROC ADDS r3,r1,#1 CMP r3,#1 IT LS BXLS lr PUSH {r4-r9} ADDS r1,r2,#2 LSRS r3,r3,#2 arm_bitreversal_32_0 ;/* loop unrolled by 2 */ LDRH r8,[r1,#4] LDRH r9,[r1,#2] LDRH r2,[r1,#0] LDRH r12,[r1,#-2] ADD r8,r0,r8 ADD r9,r0,r9 ADD r2,r0,r2 ADD r12,r0,r12 LDR r7,[r9,#0] LDR r6,[r8,#0] LDR r5,[r2,#0] LDR r4,[r12,#0] STR r6,[r9,#0] STR r7,[r8,#0] STR r5,[r12,#0] STR r4,[r2,#0] LDR r7,[r9,#4] LDR r6,[r8,#4] LDR r5,[r2,#4] LDR r4,[r12,#4] STR r6,[r9,#4] STR r7,[r8,#4] STR r5,[r12,#4] STR r4,[r2,#4] ADDS r1,r1,#8 SUBS r3,r3,#1 BNE arm_bitreversal_32_0 POP {r4-r9} BX lr ENDP arm_bitreversal_16 PROC ADDS r3,r1,#1 CMP r3,#1 IT LS BXLS lr PUSH {r4-r9} ADDS r1,r2,#2 LSRS r3,r3,#2 arm_bitreversal_16_0 ;/* loop unrolled by 2 */ LDRH r8,[r1,#4] LDRH r9,[r1,#2] LDRH r2,[r1,#0] LDRH r12,[r1,#-2] ADD r8,r0,r8,LSR #1 ADD r9,r0,r9,LSR #1 ADD r2,r0,r2,LSR #1 ADD r12,r0,r12,LSR #1 LDR r7,[r9,#0] LDR r6,[r8,#0] LDR r5,[r2,#0] LDR r4,[r12,#0] STR r6,[r9,#0] STR r7,[r8,#0] STR r5,[r12,#0] STR r4,[r2,#0] ADDS r1,r1,#8 SUBS r3,r3,#1 BNE arm_bitreversal_16_0 POP {r4-r9} BX lr ENDP END
by defining the following expression in the options for target->Asm->Misc Controls, problem will be solved.
--cpreproc
