Hi, any idea how to interface ADC0804 with 8051? I conenct the ADC0804 D7-D0 (Pin Pin 11 – Pin 18) to the 8051 P1.7 - P1.0 (Pin 8 – Pin 1). However, its not giving me the expected result. then I tried on ADC0804 chip itself and it does work with LED indication. but when interface with 8051, it just couldn't work. this is the code I used, can anyone help me? Thanks in advance!
#include <ds89c4xx.h>
sbit adc_port = P2; //ADC port sbit rd = P0^2; //Read signal P0.2 sbit wr = P0^1; //Write signal P0.1 sbit cs = P0^3; //Chip Select P0.3 (((pin5 of pull up))) sbit intr = P0^0; //INTR signal P0.0 sbit mybit = P0^7; //high/low compare value result
void conv(); //Start of conversion function void read(); //Read ADC function
unsigned char adc_data;
void main() {
while (1) { //Forever loop conv(); //Start conversion read(); //Read ADC
if (adc_data <= 0X40) //Send the read and compare if value is less than 40 in hex, 64 in decimal. More than 50cm away <1.25V { mybit=1 ; // set P0.7 high } else { mybit=0 ; // set P0.7 low } } }
void conv() { cs = 0; //Make CS low wr = 0; //Make WR low wr = 1; //Make WR high (start conversion) cs = 1; //Make CS high while (intr); //Wait for INTR to go low }
void read() { cs = 0; //Make CS low rd = 0; //Make RD low adc_data = adc_port; //Read data from ADC0804 port rd = 1; //Make RD high cs = 1; //Make CS high }
Your text talks about using P1 on 8051, but the source code mentions P2 and P0.
This can be a danger with using someone else's code - you also need to understand the code and figure out if the code does what you need it to do. And how to possibly modify the code.
See: www.8052.com/.../160143
Note that a key to this is studying & paying attention to the documentation. This you singularly failed to do when posting "your" code - resulting in the loss of the layout/indentation.
Look at the picture: www.danlhenry.com/.../keil_code.png - if you can't follow simple, clearly-stated instructions like this, you are certainly going to struggle with using the 8051 and ADC0804!
