Is Tiva TM4C123G is supported by ARM-MDK510?
whatis the difference beween 510,474 and 473?
http://www.keil.com/arm/chips.asp
http://www.keil.com/arm/new.asp
http://www.keil.com/update/rvmdk.asp
Hello Sujith,
if you want to know which devices are supported by MDK Version 5, please check out http://www.keil.com/dd2. This is the new device database for all devices that a re supported with a software pack.
Kind regards,
Christopher
Note that there should not be any dot at the end of the link: http://www.keil.com/dd2
