Whenever I try to debug or load the flash for my lpc1114 microcontroller I get the "Could not load file" error for my projects .axf file. I'm not sure what file this is any insight would be appreciated.
Are you sure you had a successful build of the project. The axf file I am pretty sure is a output of a succesful build. Usually I see a similar error when I use for example a Keil example project for the first time and it has not been build(compiled). As soon as I build it a axf file is found and the error goes away for me.
