Hi, I am trying to get messages from my mailbox to display it on my LCD Screen. However, my IRQ is always displaying the Full Message and my os_mbx_wait always timeout even when the mailbox is full.
Is there anything I am missing? FYI, Task1 has a lower priority (sender event to activate irq) and task2 has a higher priority (it will sleep)
TIA :)
extern os_mbx_declare (mailbox1, 20); //IRQ unsigned char dd_in_progress; __irq void _IRQ_Handler (void) { val1 = ->DR0 & 0x03FF; val2 = ->DR1 & 0x03FF; ddC->CR &= 0xFFFE; ddC->CR &= 0x7FFF; VIC0->VAR = 0; VIC1->VAR = 0; if (isr_mbx_check (&mailbox1) == 0) { LCD_puts("Full"); } isr_mbx_send(mailbox1, (void *)val1); dd_in_progress = 0; } //END IRQ void start_ddC ( ) { if (!dd_in_progress) { dd_in_progress = 1; ddC->CR |= 0x0423; } } __task void Task1(void){ // timing const unsigned int period = 200; os_itv_set(period); for(;;){ os_itv_wait(); /* Do actions below */ start_ddC(); } } // End /*---------------------------------------------------------------------------- * Task 2: *---------------------------------------------------------------------------*/ __task void Task2(void){ // timing const unsigned int period = 100; int light; short *data; short value; char displayMsg[15]; OS_RESULT x; os_itv_set(period); for(;;){ os_itv_wait(); /* Do actions below */ x = os_mbx_wait (&mailbox1, (void**)&data, 200); if (x != OS_R_TMO) { value=(short)*data; sprintf(displayMsg, "Value: %d", value); LCD_puts(displayMsg); LCD_cur_off(); } else if (x == OS_R_TMO) { LCD_puts("Timeout"); } free(data); } } // End
