can't debug fatal error in my gsm code.
i am facing a problem in Keil uVision3 while running a gsm code. the output window shows fatal error, that i can't debug in the program
unsigned char Rxmsg()
 unsigned char i = 0, ret = 0;
 unsigned int j = 0;
 unsigned char p[90];
 for(i = 0; i < 90; i++)
 p[i] = 0x00;
 i = 0;
 SBUF = 'a';
 while(TI == 0);
 TI = 0;
 SBUF = 't';
 while(TI == 0);
 TI = 0; SBUF = '+';
 while(TI == 0);
 TI = 0;
 SBUF = 'c';
 while(TI == 0);
 TI = 0;
 SBUF = 'm';
 while(TI == 0);
 TI = 0;
 SBUF = 'g';
 while(TI == 0);
 TI = 0;
 SBUF = 'r';
 while(TI == 0);
 TI = 0;
 SBUF = '=';
 while(TI == 0);
 TI = 0;
 SBUF = '1';
 while(TI == 0);
 TI = 0;
 SBUF = 0x0D;
 while(TI == 0);
 TI = 0;
 j = 0;
 while(RI == 0)
 if(j >= 1000)
 delay(1);
 j++;
 }  p[i] = SBUF;
 RI = 0;
 show(p[i]);
 cmnd(0x18);
 return ret;
output shows:
Build target 'Target 1'
assembling STARTUP.A51...
compiling gsm.c...
C51 COMPILER V8.02
COPYRIGHT KEIL ELEKTRONIK GmbH 1987 - 2006
*** WARNING C500 IN LINE 1 OF ..\GSM.C: INCORRECT LICENSE ID CODE (LIC) IN 'TOOLS.INI'
C51 FATAL-ERROR - ACTION: GOBAL OPTIMIZATION FUNCTION: Rxmsg ERROR: CANNOT OPTIMIZE FUNCTION
COMPILATION TERMINATED.
use the following work-around: #pragma OPTIMIZE (7) /* your original function */ Rxmsg () { .... } /* end of your original function */ #pragma OPTIMIZE (8)
Target not created.
  • Lots of fun things.
    1) Why not care about the warning you get about your license?
    2) Why so much code for sending an AT command - isn't it better with a function send_string() instead of you playing with the individual characters?
    3) Why have a while loop that busy-loops and then now-and-then inserts a call to another delay function?
    4) How can you be sure that the modem has exactly 90 characters to send? What happens if the modem only sends 87 characters?
    5) How easy to read is code that contains magical expressions like: "cmnd(0x18);"
  • Just a footnote:
    This is a quite large buffer for a 8051, unless it is placed as xdata. Best of all? You are never making use of the full array. You assign the nth position and then you directly print the nth position. Then you never return to that position again.
