I have installed my Keil license (floating) on PC which is running on Windows XP. Now we need to upgrade the server PC to Windows 7 . If i do that will i be able to access the license again. if not what is the solution to avoid reinstalling the license after OS upgradation.?
Thanks & Regards Sanish
BEFORE the upgrade you must 'delicence' the Keil in the livcence windoe, making notes of all fields. then, after the upgrade, reinstall Keil and enter the license
Hi
Thank you Erik, Could you please explain the steps to 'delicense' the Keil from WINDOWS.
www.keil.com/.../readmefirst.pdf
