Python libs to communicate with ULINK2
Hi Everyone,
I am trying to download hex file(s) using ULINK2 without actually having Keil UV4 installed. Currently, I am using UV4 command line utility to download hex which at the end requires uvproj file.
I was just curious if there is any such library (preferably python) available which could be used to communicate with ULINK2 for downloading .hex or .bin files without having Keil UV4.
Below are the system/environment details I am using it with:
Operating System: Windows 7
IDE-Version:
 µVision V4.73.0.0
Copyright (C) 2013 ARM Ltd and ARM Germany GmbH. All rights reserved.
License Information:
Swapnil Chhajer
XXXXXXXXX
LIC=XXXX-XXXX-XXXX-XXXX-XXXX-XXXX
Tool Version Numbers:
Toolchain:        MDK-ARM Standard: 8 user  Version: 4.73.0.0
Toolchain Path:    C:\Keil\ARM\ARMCC\bin\
C Compiler:         Armcc.Exe       V5.03.0.76
Assembler:          Armasm.Exe       V5.03.0.76
Linker/Locator:     ArmLink.Exe       V5.03.0.76
Librarian:             ArmAr.Exe       V5.03.0.76
Hex Converter:      FromElf.Exe       V5.03.0.76
CPU DLL:               SARMCM3.DLL       V4.73.0.0
Dialog DLL:         DCM.DLL       V1.10.0.0
Target DLL:             UL2CM3.DLL       V1.150.17.0
Dialog DLL:         TCM.DLL       V1.14.1.0
Could anyone please help me with it?
Thanks,
Swapnil
