i did this code #include <REGX51.H> #include<stdio.h> #include<string.h>
#define rs P3_5 //pin4 #define rw P0_6 //pin5 #define en P3_4 //pin6
void delay(int); void lcd_init(); void printlcd(unsigned char *str); void recieve() ; void lcd_display(char a); void lcd_command(char a); char a; unsigned int i; unsigned char dat[12]; void main() { P1=0xFF; lcd_init(); printlcd("EMB LAB"); TMOD =0x20; //Timer1 in Mode2. TCON=0x40; TH1=-3; // 9600 Baud rate at 11.0592MH SCON=0x50; // Asynchronous mode 8-bit data and 1-stop bit //IE=0x90; TR1=1; while(1) {
while (RI==0); lcd_command(0xC0); ACC=SBUF; lcd_display(ACC); RI=0; delay(100); } }
/* /// Not used in this unction////////////////// void lcd_ready() { en=0; P1=0x80; rs=0; //Control register rw=1; //Read wait: en=0; en=1; if(P1_7==1)goto wait; P1=0x00; en=0; } */ ///////////////////////////////////////////////// void lcd_display(char a) { //lcd_ready(); delay(100); P1=a; rs=1; rw=0; en=1; en=0; }
void lcd_command(char a) { //lcd_ready(); delay(100); P1=a; rs=0; rw=0; en=1; en=0; }
void delay (int temp) { int i; for(i=0; i<=temp;i++); }
void lcd_init() { lcd_command(0x38);/*8 bit/char,2 row of character*/ lcd_command(0x0C);/*Screen and cursor on, no blink*/ lcd_command(0x06);/*shift cursor right*/ lcd_command(0x01); lcd_command(0x80); } ////////////////////////////////////////////////////// void printlcd(unsigned char *str) { unsigned char len,i;
len=strlen(str);
for(i=0;i<=len-1;i++) { lcd_display(*str); str++; } }
but when i check the ACC and port it did not change according to SBUF but when we change SBUF the SBUF value changes.
you failed to notice "Place source code between +pre> and </pre+" above the entry field
