How to start a new project that supports Flash Download and Erase
Hi, I am trying to create a project for MCB2300 that supports FLASH download and Erase.
Is there a procedure to do this. I noticed that Blinky Program has a FLASH directory.
When I create a project from scratch there is no Flash directory in my project.
Thanks, Gary
  • http://www.keil.com/support/man/docs/uv4/uv4_flash_programming.htm
    The above page may help.
    Basically, you need to configure the [Debug] and [Utilities] tabs correctly.
    But, LPC23xx is old, maybe you should start with some Cortex-M MCU, like LPC17xx/LPC13xx/LPC11xx.
  • Thank You John, I have followed the instructions given on this webpage completely I think.
    I see the following pop up when I try to download to flash.
    checked boxes
    * use target driver for flash programming
    * use Debug Driver
    *update target before Debugging
    flash download setup
    *erase sectors
    *program
    *verify
    *reset and run
    Ram for Algorithm
    Start 0x4000_0000 size 0x0800
    LPC200 IAP2 512kB Flash On-chip Flash 500k 00000000H - 0007DFFFH
    checked boxes
    * use Debug Driver
    erase sectors
    program
    verify
    reset and run
    Ram for Algorithm
    At the moment I am also getting this error which I am trying to figure out.
    main.c(76): error: #20: identifier "T0_IRQHandler" is undefined
    The files in my project at this time are:
    LPC2300.s
    main.c LCD.h LPC23xx.h stdio.h
    strcopy.s
    Retarget.c
    IRQ.c LPC23xx.h
    LCD_4bit.c
    Serial.c
  • I found that I had commented out the following lines in main.c
    extern __irq void T0_IRQHandler (void);
    extern __irq void ADC_IRQHandler (void);
    That got rid of the error I was getting.
    Then I have had partial success:
    I am able to download to flash.
    But I am not able to erase the flash for some reason.
  • I notice when I download to flash it automatically erases the flash first.
    My question now is how can I get the IDE menu option to erase to flash to work.
    Also, I have recently bought some newer ARM boards. But I am interested in learning/exploring
    how to program ARM7TDMI-S ARM instruction set assembly right now.
  • -> I notice when I download to flash it automatically erases the flash first.
    My question now is how can I get the IDE menu option to erase to flash to work. <-
    Sounds like you can download and debug your LPC23xx; but fails to do a separate erase.
    If so, your [Debug] tab configuration is correct; but [Utilities] tab configuration is not.
  • Hi John, Looked at the Utilities area. Can not see a difference with other projects in this
    pop up area. I am happy though that I can download to flash and it erases when I do that.
    Thanks for your help, Gary
