i write a short program into my mcu then i cause keil cant not write program again always shows cannot access memory and cannot entry debug mode, it not cause by hardware i sure, two board with same problem and i check my program not use jtag port also there are my program codes:
main: int main(void){ Set_System(); SystemInit(); RCC_init(); GPIO_init(); USB_Interrupts_Config(); usart3_init(); USB_Init(); while(1){ } }
Set_System: void Set_System(void) { RCC_DeInit(); /* Enable HSE */ RCC_HSEConfig(RCC_HSE_ON);
/* Wait till HSE is ready */ HSEStartUpStatus = RCC_WaitForHSEStartUp();
if (HSEStartUpStatus == SUCCESS) {
/* HCLK = SYSCLK */ RCC_HCLKConfig(RCC_SYSCLK_Div1);
/* PCLK2 = HCLK */ RCC_PCLK2Config(RCC_HCLK_Div1);
/* PCLK1 = HCLK/2 */ RCC_PCLK1Config(RCC_HCLK_Div2);
/* PLLCLK = 8MHz * 9 = 72 MHz */ RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9);
/* Enable PLL */ RCC_PLLCmd(ENABLE);
/* Wait till PLL is ready */ while (RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET) { }
/* Select PLL as system clock source */ RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
/* Wait till PLL is used as system clock source */ while(RCC_GetSYSCLKSource() != 0x08) { } } else { while (1) { } }
/* enable the PWR clock */ RCC_APB1PeriphClockCmd(RCC_APB1Periph_PWR, ENABLE); }
SystemInit, in file system_stm32f10x.c
RCC_init void RCC_init(void){ RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_GPIOB|RCC_APB2Periph_GPIOC, ENABLE); RCC_APB1PeriphClockCmd(RCC_APB1Periph_USB|RCC_APB1Periph_USART3, ENABLE); RCC_USBCLKConfig(RCC_USBCLKSource_PLLCLK_1Div5); }
GPIO_init void GPIO_init(void){ GPIO_InitTypeDef GPIO_InitStructure;
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_15; //¾àÀëָʾºìµÆ GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_Init(GPIOB, &GPIO_InitStructure); GPIO_SetBits(GPIOB,GPIO_Pin_15);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13; //¾àÀëָʾÂÌµÆ GPIO_Init(GPIOC, &GPIO_InitStructure); GPIO_ResetBits(GPIOC,GPIO_Pin_13);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8; //¾àÀëָʾÀ¶µÆ GPIO_Init(GPIOB, &GPIO_InitStructure); GPIO_ResetBits(GPIOB,GPIO_Pin_8);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_14; //״ָ̬ʾºìµÆ GPIO_Init(GPIOC, &GPIO_InitStructure); GPIO_SetBits(GPIOC,GPIO_Pin_14);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13; //״ָ̬ʾÂÌµÆ GPIO_Init(GPIOC, &GPIO_InitStructure); GPIO_ResetBits(GPIOC,GPIO_Pin_13);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5; //test_LED GPIO_Init(GPIOB, &GPIO_InitStructure); GPIO_ResetBits(GPIOB,GPIO_Pin_5);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8; //usb test GPIO_Init(GPIOA, &GPIO_InitStructure); GPIO_SetBits(GPIOA,GPIO_Pin_8);
void USB_Interrupts_Config(void)
{ NVIC_InitTypeDef NVIC_InitStructure;
/* 2 bit for pre-emption priority, 2 bits for subpriority */ NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);
/* Enable the USB interrupt */ NVIC_InitStructure.NVIC_IRQChannel = USB_LP_CAN1_RX0_IRQn; NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1; NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0; NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; NVIC_Init(&NVIC_InitStructure); }
void usart3_init(void){ GPIO_InitTypeDef GPIO_InitStruct; USART_InitTypeDef USART_InitStruct; NVIC_InitTypeDef NVIC_InitStructure;
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE); //¿ªIOʱÖÓ
GPIO_InitStruct.GPIO_Mode = GPIO_Mode_AF_PP; GPIO_InitStruct.GPIO_Pin = GPIO_Pin_10; GPIO_InitStruct.GPIO_Speed = GPIO_Speed_50MHz; GPIO_Init(GPIOB, &GPIO_InitStruct); // tx
GPIO_InitStruct.GPIO_Mode = GPIO_Mode_IN_FLOATING; GPIO_InitStruct.GPIO_Pin = GPIO_Pin_11; // Rx GPIO_Init(GPIOB, &GPIO_InitStruct);
RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART3,ENABLE);//¿ªUSARTʱÖÓ USART_InitStruct.USART_BaudRate = 38400; USART_InitStruct.USART_StopBits = USART_StopBits_1; USART_InitStruct.USART_WordLength = USART_WordLength_8b; USART_InitStruct.USART_Parity = USART_Parity_No; USART_InitStruct.USART_HardwareFlowControl = USART_HardwareFlowControl_None; USART_InitStruct.USART_Mode = USART_Mode_Tx | USART_Mode_Rx; USART_Init(USART3, &USART_InitStruct); USART_ITConfig(USART3,USART_IT_RXNE,ENABLE);//ʹÄܽÓÊÕÖÐ¶Ï USART_Cmd(USART3, ENABLE);//ʹÄÜ´®¿Ú3
NVIC_InitStructure.NVIC_IRQChannel = USART3_IRQn; NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 2; NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1; NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; NVIC_Init(&NVIC_InitStructure);
void USB_Init(void) { pInformation = &Device_Info; pInformation->ControlState = 2; pProperty = &Device_Property; pUser_Standard_Requests = &User_Standard_Requests; /* Initialize devices one by one */ pProperty->Init(); }
there are content of my codes, i check found two problem re-init rcc clock and re-init gpio i think re-init gpio should not cause this problem so is this problem cause by re-init rcc clock? and how to solve it without replace a new mcu?
Are you using a eval board or a custom board. Which manufacturer? Do you have example projects that already work? Are you sure that the project options are set properly for your project?
Did you set the frequency APB2. Looks like there is a SRAM there.
It looks to me you set up your clocks correctly. Sorry for all these comments.
See if the Flash Latency is correctly set.
This sounds like you are hard faulting VERY EARLY in the program, before the JTAG can get control. You will need to set the Boot0 pin HIGH (externally) and boot the system. It will boot into a stable piece of code. Once you boot into that you can access the chip thought the JTAG. If you are designing a board, always make sure you have access to the Boot0 pin so you can do this.
I wonder if the Uart0 uart is connected to a PC and is affecting the Boot pin and causing the boot0 signal to be in the wrong state. I had similar problem and I decided to make a simpler uart cable that only had pin 2 and 3 hooked up to avoid this.
its a custom board and now i found the program works fine on eval board, im checking maybe port define error or schematic problem
It looks like you are writing code for an STM32 part.
Make sure to run the STM32CubeMX tool and double check your clock and timing values in there.
The tool will help you catch bad settings (flag them red).
Please refer to: http://www.keil.com/pack/doc/STM32Cube/General/html/index.html
This shows how to use STM32Cube, CubeMX, and CMSIS-Driver within the Keil IDE.
To help your fellow forum followers, it helps if you
put persnickety problem code in "pre" tags
__asm volatile ( //"headSP:\n\t" "push {r0,r1,r2,r3}\n\t"
see:
http://www.keil.com/forum/tips.asp
