to check the mapping for one input to one output in my application
sir i am facing a problem to map my inputs and outputs in the if condition that is in read input data bit for multiple pins kindly help me the same.
#include "stm32f0xx.h"
#include "stm32f0308_Discovery.h"
#define out0 GPIO_Pin_0
#define out1 GPIO_Pin_1
#define out2 GPIO_Pin_2
#define out3 GPIO_Pin_3
#define out4 GPIO_Pin_4
#define out_GPIO GPIOC
void TM_Delay_Init(void);
void TM_DelayMillis(uint32_t millis);
void TM_DelayMillis1(uint32_t millis);
void TM_DelayMillis2(uint32_t millis);
GPIO_InitTypeDef GPIO_InitStructure ;
uint32_t multiplier;
int main(void)
  SystemInit();
  SystemCoreClockUpdate();
  RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA | RCC_AHBPeriph_GPIOC, ENABLE);
                /* Configure PA in input mode */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 ;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN;
GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
GPIO_Init(GPIOA, &GPIO_InitStructure);
                /*configure PC in output mode */
GPIOC->MODER  |= ((GPIO_MODER_MODER0_0)|(GPIO_MODER_MODER1_0)|(GPIO_MODER_MODER2_0)|(GPIO_MODER_MODER3_0)|(GPIO_MODER_MODER4_0)|(GPIO_MODER_MODER5_0)) ;
        //GPIOC-> GPIO_MODER_MODER8_0 = 0x01;
GPIOC->OTYPER &= ~((GPIO_OTYPER_OT_0)|(GPIO_OTYPER_OT_1)|(GPIO_OTYPER_OT_2)|(GPIO_OTYPER_OT_3)|(GPIO_OTYPER_OT_4)|(GPIO_OTYPER_OT_5)) ;
        //GPIOC->OTYPER = 0x00;
GPIOC->OSPEEDR |= ((GPIO_OSPEEDER_OSPEEDR0)|(GPIO_OSPEEDER_OSPEEDR1)|(GPIO_OSPEEDER_OSPEEDR2)|(GPIO_OSPEEDER_OSPEEDR3)|(GPIO_OSPEEDER_OSPEEDR4)|(GPIO_OSPEEDER_OSPEEDR5));
        //GPIOC->OSPEEDR = 0x00;
GPIOC->PUPDR &= ~((GPIO_PUPDR_PUPDR0)|(GPIO_PUPDR_PUPDR1)|(GPIO_PUPDR_PUPDR2)|(GPIO_PUPDR_PUPDR3)|(GPIO_PUPDR_PUPDR4)|(GPIO_PUPDR_PUPDR5));
        while(1)
                if(GPIO_ReadInputDataBit(GPIOA, GPIO_Pin_0)==1)
                                GPIO_SetBits(GPIOC,(out0)|(out1)|(out2)|(out3)|(out4));
                                TM_DelayMillis(7);
                                GPIO_ResetBits(GPIOC,(out0)|(out1)|(out2)|(out3)|(out4));
                                while (GPIO_ReadInputDataBit(GPIOA, GPIO_Pin_0)==1)
                                TM_DelayMillis1(3);
                                TM_DelayMillis2(22);
void TM_DelayMillis(uint32_t millis) { /* Multiply millis with multipler */ /* Substract 10 */ millis = 100 * millis * multiplier - 10; /* 4 cycles for one loop */ while (millis--);
void TM_DelayMillis1(uint32_t millis) { /* Multiply millis with multipler */ /* Substract 10 */ millis = 1 * millis * multiplier - 10; /* 4 cycles for one loop */ while (millis--);
void TM_DelayMillis2(uint32_t millis) { /* Multiply millis with multipler */ /* Substract 10 */ millis = 1 * millis * multiplier - 10; /* 4 cycles for one loop */ while (millis--);
void TM_Delay_Init(void) { RCC_ClocksTypeDef RCC_Clocks;
/* Get system clocks */ RCC_GetClocksFreq(&RCC_Clocks);
/* While loop takes 4 cycles */ /* For 1 us delay, we need to divide with 4M */ multiplier = RCC_Clocks.HCLK_Frequency / 4000000;
  • If it was my project I would try the following. First I would need a oscilloscope to view the created signals.
    Second, I would obtain a solderless breadboard and wires to wire up the header pins to the bread board.
    I would wire up the following pins as input
    Inputs
    P1.15 PA0
    P1.16 PA1
    P1.17 PA2
    P1.18 PA3
    P1.21 PA4
    P1.22 PA5
    Outputs
    P1.27 PB0
    P1.28 PB1
    P1.29 PB2
    P2.11 PA3
    P2.10 PA4
    P2.9 PA5
    and GROUND AND THREE VOLTS
    P1.1 3 Volts
    P1.2 GND
    All this information can be checked by looking at the schematic.
    Then inputs can be set hi or low on the Breadboard as required.
    then in a loop you can read the input pins as a 32 bit word.
    I think you can take that word and write it to the outputs to set/reset the outputs as the inputs are configured (timed as needed).
