I'm working with the µVision5 (V5.16.0.0) and I'm trying to debug a hard fault of an STM32F0. I wanted to use the Fault Reports Dialog but then I saw that it's missing. I know it sould be in Peripherals->Core peripherals->Fault Reports. But the Fault Reports is just not listend (only Nested Vector Interrupt Controller, System Controll and Configuration and System Tick Timer). Do I have to install something to be able to use it?
I am having exactly the same issue. Did you find a way to get to the Fault Report after all?
Thanks!
Cortex-M0 devices do not have such Fault Reports. You need to use the call stack to find the location of the problem.
