Bulk transfer of Data via USB (Host side)
Hi everyone,
I am using a LM3S5951 controllers for one of my projects in which I need to implement a host side driver for Dot Matrix printer .
I am done with enumeration of the printer, but now I would like to know how can I send data to printers using bulk transfers. I am using the Stellaries USB Library for the same where I found some host side codes for keyboard and pendrive. I would like to know, how to go about this.
Regards
Dhanush
  • A) Before starting
    firmware coding, you have to examine the printer on a PC, to know the printer protocols better.
    1) Read out these information from the printer, using USB sniffer on the PC.
    - Device and Configuration descriptor set.
    The descriptor set is used to check if your firmware reads them out correctly or not.
    - Printer’s Device ID string
    In the enumeration, PC reads out Device ID string using GET_DEVICE_ID request (control transfer), of this SETUP packet layout.
    bmRequestType: 0xA1
    bRequest     : 0x00 (GET_DEVICE_ID)
    wValue       : 0x01 (config index)
    wIndex       : 0x00 (Interface / Alternate)
    wLength      : length of ID string
    Here is the Device ID string of an old laser printer (EPSON LP-2400) on my desktop.
    00 6B 4D 46 47 3A 45 50 53 4F 4E 3B 43 4D 44 3A   .kMFG:EPSON;CMD:
    45 4A 4C 2C 45 53 43 50 32 34 4A 2D 38 34 2C 45   EJL,ESCP24J-84,E
    53 43 50 41 47 45 4A 2D 30 34 2C 45 53 43 50 53   SCPAGEJ-04,ESCPS
    55 50 45 52 2D 30 30 2C 50 52 32 30 31 2D 30 30   UPER-00,PR201-00
    3B 4D 44 4C 3A 4C 50 2D 32 34 30 30 3B 43 4C 53   ;MDL:LP-2400;CLS
    3A 50 52 49 4E 54 45 52 3B 44 45 53 3A 45 50 53   :PRINTER;DES:EPS
    4F 4E 20 4C 50 2D 32 34 30 30 3B                  ON LP-2400;
    "CMD:" tag on the Device ID string shows the PDL (Page Description Language), applied to print data. In above example,
    CMD:EJL,ESCP24J-84,ESCPAGEJ-04,ESCPSUPER-00,PR201-00;
    This printer supports Epson ESC/P and PC-PR201 enumeration.
    You may use these sniffers on Windows,
    USBlyzer (commercial, 33 days trial) http://www.usblyzer.com/
    USBTrace (commercial, 15 days trial) http://www.sysnucleus.com/
    To read out device/config descriptors and Device ID string, the enumeration sequence of the printer is traced. To catch enumeration on USBlyzer, you'll need to enable "Capture menu -> Capture Hot-plugged" before plugging in the target printer to the PC.
    2) Make a "test page" data on the PC
    - First of all, your PC should be installed the correct driver of the printer.
    - Make a "test page" on a text editor, like WordPad, as close to your required page layout as possible.
    - Print the page on the printer from the PC, tuning the page layout until you are satisfied.
    - When the page finishes, switch to "Print to File"
    On Windows7, bottom Start button > Device and printers > right click on the target printer > Printer’s properties > Ports tab
    Check "FILE: Print to File"
    And then, print the "test page" on the editor.
    Now that you have "test page" data on a file.
    To be continued..
    Tsuneo
  • B) StellarisWare implementation
    This implementation is based on StellarisWare 10630
    First, host class instance and DriveOpen()/DriveClose() are easily made, modifying mass storage source code (copy/paste-global replace).
    // printer host class instance
    // and USBHPRNDriveOpen() / USBHPRNDriveClose()
    typedef void (*tUSBHPRNCallback)(unsigned long ulInstance,
                                     unsigned long ulEvent,
                                     void *pvEventData);
    typedef struct
        // Save the device instance.
        tUSBHostDevice *pDevice;
        // Used to save the callback.
        tUSBHPRNCallback pfnCallback;
        // class specific members
        // Bulk IN pipe.
        unsigned long ulBulkInPipe;
        // Bulk OUT pipe.
        unsigned long ulBulkOutPipe;
    tUSBHPRNInstance;
    static tUSBPRNInstance g_USBHPRNDevice =
        0
    unsigned long
    USBHPRNDriveOpen(unsigned long ulDrive, tUSBHPRNCallback pfnCallback)
        // Only the first drive is supported and only one callback is supported.
        if((ulDrive != 0) || (g_USBHPRNDevice.pfnCallback))
            return(0);
        // Save the callback.
        g_USBHPRNDevice.pfnCallback = pfnCallback;
        // Return the requested device instance.
        return((unsigned long)&g_USBHPRNDevice);
    void
    USBHPRNDriveClose(unsigned long ulInstance)
        tUSBHPRNInstance *pPRNDevice;
        // Get a pointer to the device instance data from the handle.
        pPRNDevice = (tUSBHPRNInstance *)ulInstance;
        // Close the drive (if it is already open)
        USBHPRNClose((void *)pPRNDevice);
        // Clear the callback indicating that the device is now closed.
        pPRNDevice->pfnCallback = 0;
    And then, host driver instance
    #define PRN_EVENT_OPEN          1
    #define PRN_EVENT_CLOSE         2
    static void *USBHPRNOpen(tUSBHostDevice *pDevice); static void USBHPRNClose(void *pvInstance);
    const tUSBHostClassDriver g_USBHostPRNClassDriver = { USB_CLASS_PRINTER, USBHPRNOpen, USBHPRNClose, 0 };
    Copy these routines from usbhmsc.c, and replace all "MSC" with "PRN"
    USBHPRNOpen() <- USBHMSCOpen()
    USBHPRNClose() <- USBHMSCClose()
    Delete this line from copied USBHPRNOpen() g_USBHMSCDevice.ulMaxLUN = 0xffffffff;
    USBHPRNOpen() opens the bulk IN/OUT pipes.
    Using the OUT pipe, the data on pBuffer is sent to the printer, as follows.
    You may send any size of buffer, even greater than 64 bytes with single USBHCDPipeWrite() call.
        ulBytes = USBHCDPipeWrite(g_USBHPRNDevice.ulBulkOutPipe,
                                  (unsigned char*)pBuffer, sizeof(pBuffer));
    Tsuneo
  • Hi Tsuneo , I have already tried with USBHCDPipeWrite().I pass a string in this function and it prints only if the string ends with a carriage return () .
    But how to print multiple strings in a single line . I tried writing the code in a for loop , now printer prints once in every 4 times command send.
    I think there is garbage in pipes or not a proper HCD pipe write usage.
    Regards,
    Dhanush.
  • > I think there is garbage in pipes or not a proper HCD pipe write usage.
    What is the PDL supported by the printer?
    Before making such groundless assumption, you have to know printing protocol (ie. PDL)
    In my first post, I said you should find the PDL before coding your firmware.
    Tsuneo
  • Hi,
    The Printer I am using is epson LX-300 and it supports ESC/P 9 pin PDL format. Can u please tell me now how should I go about this. The bold print and double print commands are working fine, I am facing the same problem discussed above.
    The first time I send a string to be printed, it works. But the second time it prints garbage data.
    Regards
    Dhanush
  • Hi Tsuneo,
    I successfully intterfaced the dot matrix printer using the details provided by you for LM3S5951 controller.
    I am using an epson LX-300 printer which supports esc/p2 pdl.
    now when eveytime I send data to printer preceded by an init printer command , the printer prints data.
    But now when I send data w/o init printer command it prints data once in every two tries.
    Please provide some solution.
    Regards
    Sanket K
  • Answered to Dhanush in TI Stellaris forum,
    e2e.ti.com/.../1172109.aspx
    Sanket,
    ESC/P line printer prints data on its buffer to paper, when it receives LF (0x0A).
    On your code, you may terminate a string with LF, like "ABCD\n"
    Tsuneo
  • Hi Tsuneo,
    Now that I have successfully interfaced the printer using USB, everything is working fine.
    I would also like to check whether the printer is busy or not like it has been checked using the 25 pin centronics using LPT. How could I achieve this I have one IN endpoint for the printer.
    Regards
    Dhanush
  • > I have one IN endpoint for the printer.
    The bulk IN endpoint of the printer interface is optional.
    It’s role is specific to each printer model.
    Unfortunately, Epson doesn’t open the information of the role (protocol) over the bulk IN.
    You may get some printer status, or nothing.
    Try it.
    ulBytes = USBHCDPipeRead( g_USBHPRNDevice.ulBulkInPipe, pBuffer, sizeof(pBuffer) );
    NAK on the bulk OUT endpoint corresponds to the BUSY signal of Centronics.
    While the endpoint is NAKing, USBHCDPipeWrite() (and USBHCDPipeRead()) blocks the caller thread. I believe this is the reason why you need "BUSY" signal.
    Instead of these blocking calls, you may apply non-blocking USBHCDPipeSchedule() to start transfer over the bulk IN or OUT endpoint.
    USBHCDPipeSchedule( g_USBHPRNDevice.ulBulkOutPipe, pBuffer, sizeof(pBuffer) );
    or
    USBHCDPipeSchedule( g_USBHPRNDevice.ulBulkInPipe, pBuffer, sizeof(pBuffer) );
    When the transfer finishes, callback is called for each endpoint.
    This callback is registered at USBHCDPipeAllocSize() in your USBHPRNOpen()
    static void PRNEndpointCallback(uint32_t ui32Pipe, uint32_t ui32Event);
    static void *
                    g_sUSBHMSCDevice.ui32BulkInPipe =
                        USBHCDPipeAllocSize(0, USBHCD_PIPE_BULK_IN_DMA,
                                            psDevice,
                                            psEndpointDescriptor->wMaxPacketSize,
                                            PRNEndpointCallback);    // <-------
                    g_sUSBHMSCDevice.ui32BulkOutPipe =
                        USBHCDPipeAllocSize(0, USBHCD_PIPE_BULK_OUT_DMA,
                                            psDevice,
    In the callback,
    static void
      switch ( ui32Event ) {
        case USB_EVENT_TX_COMPLETE:   // transfer on OUT endpoint finishes
          // notify to the main thread by a flag, or start another transfer
          break;
        case USB_EVENT_RX_AVAILABLE:  // transfer on IN endpoint finishes
          // read out data into a buffer
          USBHCDPipeReadNonBlocking( g_USBHPRNDevice.ulBulkInPipe, pBuffer, sizeof(pBuffer) );
          break;
        default: break;
    Tsuneo
  • Hi Tsuneo ,
    I wish to interface a Laser printer (high USB speed device) to my ARM controller.But TIVA supports only low speed and full-speed devices . Is there any solution .Is there any interfacing circuitry ???
    Regards,
    Sanket
  • > But TIVA supports only low speed and full-speed devices .
    Surely USB host on Tiva TM4C123x supports just low-/full-speed.
    But TM4C129x does high-speed, too, with an external ULPI PHY chip.
    Unfortunately, TivaWare doesn't implement external PHY chip, yet.
    You may consider on other MCUs.
    a) STM32F2/F4 with an external ULPI PHY chip
    The low-cost pair, STM32F4 Discovery board and "USB3300 USB HS Board", is handy to play high-speed USB.
    www.wvshare.com/.../USB3300-USB-HS-Board.htm
    ST's STM32_USB-Host-Device_Lib_V2.1.0 doesn't have printer host.
    But you may write it, based on Mass-Storage host example
    In this link, we discussed on modification for CDC/RNDIS host.
    Similar modification is applied to printer host.
    my.st.com/.../DispForm.aspx
    b) LPC18xx/LPC43xx (with on-chip high-speed PHY)
    - USB host library in LPCOpen supports printer host, but no example.
    You may write it fairly easily, based on HID keyboard host example.
    www.lpcware.com/.../lpcopen-software-development-platform-lpc18xx-packages-0
    c) Raspberry PI and BeagleBone Black
    Raspbian / Angstrom Linux supports printer host.
    Tsuneo
  • Hi Tsuneo,
    I am sending data to the printer using usbhcdpipewrite. now i dont have the paper in the printer, the printer pauses, but its buffer is now full with the data that is sent. Now whenever I insert the paper it starts printing the data, but I dont want this to happen. But I have no other solution as busy line in LPT. Whether there is a solution to this or not.
    Regards
    Dhanush
  • Hi,
    I am also facing the same problem with the printer. I want to check the paper out and set a flag in my code whenever there is no paper in the printer. My requirement is like this so I have to achieve this in any case . There may be a solution to this problem.
    regards
    Sagar
  • GET_PORT_STATUS class-specific request retrieves printer status, including Paper Empty.
    USB Printing Device Class spec
    www.usb.org/.../usbprint11a021811.pdf
    4.2.2 GET_PORT_STATUS (bRequest = 1) (page 7)
    This class-specific request returns the printer's current status, in a format which is compatible with the status register of a standard PC parallel port.
    Bit(s) Field Description
    7..6  Reserved;      Reserved for future use; device shall return these bits reset to zero.
     5    Paper Empty;   1 = Paper Empty, 0 = Paper Not Empty
     4    Select;        1 = Selected,    0 = Not Selected
     3    Not Error;     1 = No Error,    0 = Error
    2..0  Reserved;      Reserved for future use; device shall return these bits reset to zero.
    This request is carried over Control Transfer. The implementation is,
    unsigned long
    GetPortStatus(unsigned long ulInstance, unsigned long ulInterface)
    #define PRN_GET_PORT_STATUS   0x01
        unsigned long        ulStatus   = 0;
        tUSBHostPRNInstance *pPRNDevice = (tUSBHostPRNInstance *)ulInstance;
        tUSBRequest          SetupPacket;
        SetupPacket.bmRequestType = USB_RTYPE_DIR_IN | USB_RTYPE_CLASS | USB_RTYPE_INTERFACE;
        SetupPacket.bRequest      = PRN_GET_PORT_STATUS;
        SetupPacket.wValue        = 0x0000;
        SetupPacket.wIndex        = (unsigned short)ulInterface;    // interface number
        SetupPacket.wLength       = 0x01;                           // one-byte status returns
        USBHCDControlTransfer(0, &SetupPacket, pPRNDevice->pDevice,
                              (unsigned char *)&ulStatus, sizeof(ulStatus),
                              pPRNDevice->pDevice->DeviceDescriptor.bMaxPacketSize0);
        return(ulStatus);
    To poll the printer status, your firmware regularly calls GetPortStatus() in every 100ms or so.
    unsigned long ulStatus = GetPortStatus( g_USBHPRNDevice.pDevice, g_USBHPRNDevice.pDevice->ulInterface );
    Tsuneo
  • Hi Tsuneo,
    Thank you for your responses. I have implemented the above things as said but whenever I read the status using GetPortStatus function described above I get result byte as '0' even if the paper is not present in the printer.
    The procedure I followed for the same is as follows:
    1: I added the implementation as discussed above to my printerhostclass.c file as it is. I understood the things mentioned in it.
    2: I have created an instance of the printer driver g_ulPRNinstance.
    3: unsigned long status=GetPortStatus(g_ulPRNinstance,0) I call the function using the above line from my main function. if((status & 0x20)== 1) do this else do that.
    Now when I start the printer w/o paper and call this function then always it executes the "else" part, where as it should execute "if" part.
    I check the value of status on uart but it shows 0. Am I doing something wrong here, if yes then what should I do
    Dhanush
