Are there any settings or commands needed before I can use calloc in a function? I am trying to allocate memory for 3 arrays using three separate pointers and calloc functions. I know the amount of memory I am requesting is well under the RAM limit but I am getting a null error when I try to allocate the third array. The part is a ADuCM360.
Check heap allocation in startup.s
www.keil.com/.../search.asp
First hit is, "Creating the heap for use with microlib"
