PLEASE FIND D CODE BELOW AND SUGGEST CHANGES I NEED TO MAKE TO GET "OFF TIME OF SQUARE PULSE".. . i am using EX0 and TR0 interrupt to find low pulse time.
THANKS IN ADVANCE.
/*program to find the toff*/
#include <reg51.h> #include <stdio.h>
sbit led=P1^0;
unsigned int count = 0,flag=0;
void EX0_ISR (void) interrupt 0 { TR0=1; if(INT0) TR0=0; EX0=0; }
void ET0_ISR(void) interrupt 1 { count++; TF0=0; }
void main (void) { SCON = 0x50; TMOD = 0x20; //timer 1 mode 2 auto reload TH1=-3;//9600 //TH1 = 0xFA; //Baud=9600 or -6d TR1 = 1; TI = 1; //PCON = 0x80; //setting SMOD TMOD = (TMOD & 0xF0) | 0x09; //value of TMOD =0x29 timer 0 for 16 bit mode 1
EA=EX0=ET0=1;
count=0; TH0=TL0=0;
while(1) { IT0=1; result=((unsigned long)((TH0<< 8) |TL0 | ((unsigned long)count << 16))); printf ("\noff pulse... %ld nSec\n", result);
I don't see any block of text with the proper attributes for code.
By the way - don't you think you should also clearly specify the full name of your processor?
SORRY, 'D' IS NOT A SUPPORTED LAMGUAGE - PLEASE POST IN 'C'.
And do it properly: www.danlhenry.com/.../keil_code.png
