Hi there,
I have been doing I2C and very new to it. I already make it to work using PCF8575C. I managed to read all two bytes, but I can't seem to figure out how to only get the value of one bit. For example, previously before using I2C, I juts directly create a condition which (if p1_0 == 1, True.. Else, False). I want to use the same concept but unable to get it right. Below is my code:
case 'R': I2C_Start(); I2C_Write(0x43); I2C_Read(); I2C_Read_End(); I2C_Stop(); break; void I2C_Write(unsigned char Data) { unsigned char i; for (i = 1; i <= 8; i++) { SDA = (Data >> 7); SCL = 1; Delay_1sec(); Data = Data << 1; SCL = 0; Delay_1sec(); } SCL = 0; SDA = 1; Delay_1sec(); SCL = 1; if(SDA) { printf("Ack bit missing %02X\n",(unsigned int)Data); } else {} Delay_1sec(); SCL = 0; } unsigned char I2C_Read() { unsigned char i; for(i=1;i<=8;i++) { SCL = 1; Data = Data << 1; //Rotate Data Bit Data = Data | (unsigned char)SDA; //Move SDA to Data and Combine Existing Data Value Delay_1sec(); SCL = 0; Delay_1sec(); } SDA = 0; SCL = 1; Delay_1sec(); SCL = 0; Delay_1sec(); SDA = 1; printf("%02X",(unsigned int)Data); return Data; } unsigned char I2C_Read_End() { unsigned char i, Data; for(i=1;i<=8;i++) { SCL = 1; Data = Data << 1; //Rotate Data Bit Data = Data | (unsigned char)SDA; //Move SDA to Data and Combine Existing Data Value Delay_1sec(); SCL = 0; Delay_1sec(); } SCL = 1; Delay_1sec(); SCL = 0; Delay_1sec(); SDA = 1; printf("%02X\n",(unsigned int)Data); return Data; }
Would be glad if someone can help me with this. Thanks!
I don't see what it has to do with I2C specifically, but:
http://www.keil.com/support/man/docs/c51/c51_le_bit.htm
http://www.keil.com/support/man/docs/c51/c51_le_bitaddrobj.htm
http://www.keil.com/support/man/docs/c51/c51_le_sbit.htm
