Hi.
I have some trouble with my SAM7X-EK. 1: I connect the USB-power and the ULINK2/JTAG to the SAM7X-EK. 2: Two green LED starts to flash because it's running the "getting-started-project-at91sam7x". 3: I launch KEIL uV4 and the project "getting-started-project-at91sam7x". 4: I Rebuild the project (OK) 5: I LOAD it OK, with the following output-text: Erase Done. Programming Done. Verify OK. ==> And now I see that the green LED has stopped flashing. 6: I enter Debug Session (the "d-icon") ==> Now I observe that the text at the bottom line of the window says: "Real-Time Agent: Checking target" for about 4 seconds until it says: "Real-Time Agent: Not in target"
And now, I cannot start my program properly !!!??? I cannot make the program "run to main", cannon "grab the CPU" by stopping it at Breakpoints etc.
When I Stop the program (the red circle with a white X), the bottom-line says: "Real-Time Agent: Target stopped". When I re-try to Run (F5) the program, the same happens once again: ==> I observe that the text at the bottom line of the window says: "Real-Time Agent: Checking target" for about 4 seconds until it says: "Real-Time Agent: Not in target"
I really would appreciate assistance with this problem.
Best Regards Terje Bohler
