I am getting the following error upon compiling a simple project for STM32F407VG on MDK version 5 for the Discovery Board. All packs are installed fine. Please note, the header file is all uppercase in this example. Any suggestions? Do I need to transition the project to version 5?
Build target 'CPUAsmLab' assembling startup_stm32f4xx.s... compiling system_stm32f4xx.c... system_stm32f4xx.c(117): error: #5: cannot open source input file "stm32f4xx.h": No such file or directory #include "stm32f4xx.h" system_stm32f4xx.c: 0 warnings, 1 error compiling main.c... src\main.c(2): error: #5: cannot open source input file "STM32F4xx.h": No such file or directory #include "STM32F4xx.h" src\main.c: 0 warnings, 1 error ".\template.axf" - 2 Error(s), 0 Warning(s). Target not created
Go to your C/C++ Project Options and ADD all the include paths you need for the project. Determine where this specific file is with respect to your project directory. Windows is case insensitive.
Thanks that worked. The location for the include had changed to
"C:\Keil_v5\ARM\Pack\Keil\STM32F4xx_DFP\1.0.8\Device\Include"
I'm a beginner, above problem occurred to me too:
C:\Keil_v5\ARM\PACK\Keil\STM32F0xx_DFP\2.0.0\Drivers\STM32F0xx_HAL_Driver\Inc\stm32f0xx_hal.h(46): error: #5: cannot open source input file "stm32f0xx_hal_conf.h": No such file or directory
i did what you said above, i.e. to include the paths for the header files needed. but got the same issue
can you explain me be specific... i cant understand to solve that??
You need to right-click in the .c file that calls the header file (or the .c that calls the header file wich calls the header [...] wich calls the header file missing, don't matters how many levels of calls), and in the "options for file", in the C/C++ tab, you must include the path of your header file that is missing.
I believe it's safe to assume that after 2 years, Athmesh is no longer in need of that information.
