Hello every one,
I have a problem with my segger J_Link debugger and KeilV5.15...I can download the code into the device using flash downloader but I can't debug my code and I have an error in Keil's command window as :
*** error 122: AGDI: memory read failed (0x062D7810)
How can I solve it ?
Is that a valid memory address in the unspecified target?
Examine why the tools would be accessing that address, check the .MAP, check the debugger script .INI, check if you have a memory view open.
