Hi, Please help me to know why the following example code for SPI of STM32L152VD is not working, I do not see any signals in scope on pins SCK and MOSI niether in Data register in dubugger.
void SPI_Master_init(void) { GPIO_InitTypeDef GPIO_InitStruct; SPI_InitTypeDef SPI_InitStruct; /* Initialization and Configuration functions *********************************/ // enable peripheral clock RCC_AHBPeriphClockCmd(RCC_APB2Periph_SPI1, ENABLE); RCC_AHBPeriphClockCmd(RCC_APB1Periph_SPI2, ENABLE); RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA, ENABLE); RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOB, ENABLE); GPIO_InitStruct.GPIO_Pin = GPIO_Pin_5 | GPIO_Pin_6 | GPIO_Pin_7; GPIO_InitStruct.GPIO_Mode = GPIO_Mode_AF; GPIO_InitStruct.GPIO_OType = GPIO_OType_PP; GPIO_InitStruct.GPIO_Speed = GPIO_Speed_40MHz; GPIO_InitStruct.GPIO_PuPd = GPIO_PuPd_NOPULL; GPIO_Init(GPIOA, &GPIO_InitStruct); GPIO_InitStruct.GPIO_Pin = GPIO_Pin_13 | GPIO_Pin_14 | GPIO_Pin_15; GPIO_InitStruct.GPIO_Mode = GPIO_Mode_AF; GPIO_InitStruct.GPIO_OType = GPIO_OType_PP; GPIO_InitStruct.GPIO_Speed = GPIO_Speed_40MHz; GPIO_InitStruct.GPIO_PuPd = GPIO_PuPd_NOPULL; GPIO_Init(GPIOB, &GPIO_InitStruct); // connect SPI1 pins to SPI alternate function GPIO_PinAFConfig(GPIOA, GPIO_PinSource5, GPIO_AF_SPI1); GPIO_PinAFConfig(GPIOA, GPIO_PinSource6, GPIO_AF_SPI1); GPIO_PinAFConfig(GPIOA, GPIO_PinSource7, GPIO_AF_SPI1); // // connect SPI2 pins to SPI alternate function GPIO_PinAFConfig(GPIOB, GPIO_PinSource13, GPIO_AF_SPI2); GPIO_PinAFConfig(GPIOB, GPIO_PinSource14, GPIO_AF_SPI2); GPIO_PinAFConfig(GPIOB, GPIO_PinSource15, GPIO_AF_SPI2); SPI_InitStruct.SPI_Direction = SPI_Direction_2Lines_FullDuplex; // set to full duplex SPI_InitStruct.SPI_Mode = SPI_Mode_Master; // transmit in master mode, NSS pin has SPI_InitStruct.SPI_DataSize = SPI_DataSize_8b; // one packet of data is 8 bits wide SPI_InitStruct.SPI_CPOL = SPI_CPOL_Low; // clock is low when idle SPI_InitStruct.SPI_CPHA = SPI_CPHA_1Edge; // data sampled at first edge SPI_InitStruct.SPI_NSS = SPI_NSS_Hard; // set the NSS HARD SPI_InitStruct.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_256; // SPI frequency is SPI_InitStruct.SPI_FirstBit = SPI_FirstBit_MSB;// data is transmitted MSB first SPI_Init(SPI1, &SPI_InitStruct); SPI_SSOutputCmd(SPI1,ENABLE); //Set SSOE bit in SPI_CR1 register SPI_Cmd(SPI1, ENABLE); // enable SPI1 SPI_InitStruct.SPI_Direction = SPI_Direction_2Lines_FullDuplex; // set to full duplex SPI_InitStruct.SPI_Mode = SPI_Mode_Master; // transmit in master mode, NSS pin has SPI_InitStruct.SPI_DataSize = SPI_DataSize_8b; // one packet of data is 8 bits wide SPI_InitStruct.SPI_CPOL = SPI_CPOL_Low; // clock is low when idle SPI_InitStruct.SPI_CPHA = SPI_CPHA_1Edge; // data sampled at first edge SPI_InitStruct.SPI_NSS = SPI_NSS_Hard; // set the NSS HARD SPI_InitStruct.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_256; // SPI frequency is SPI_InitStruct.SPI_FirstBit = SPI_FirstBit_MSB;// data is transmitted MSB first SPI_Init(SPI2, &SPI_InitStruct); SPI_SSOutputCmd(SPI2,ENABLE); //Set SSOE bit in SPI_CR1 register SPI_Cmd(SPI2, ENABLE); // enable SPI2
and in main:
int main(void){ SPI_Master_init(); while(1) { SPI_I2S_SendData(SPI1, 0xFFFF); SPI1->DR = 0x11; SPI_I2S_SendData(SPI2,0xFFFF); SPI2->DR = 0x11;
You'd probably want to be waiting on TXE before jamming data in the Data Register, and understand there are TWO registers, the one you can read in the debugger is the receiving one, not the transmitting value you're jamming in there.
It seems sth is making SPI disabled. I added wait cycle after sending data, but in scope no signal appear.
Not on the AHB
Dear Pier,
Thanks. I corrected the code.
RCC_APB1PeriphClockCmd(RCC_APB1Periph_SPI2,ENABLE); RCC_APB2PeriphClockCmd(RCC_APB2Periph_SPI1,ENABLE);
Yet I don't have signals.
looking at your code. I am wondering about if you are setting up SPI2. I see some of the lower code as duplicate of code you already typed in. You declare master mode two times. the code looks the same.
http://www.keil.com/forum/59935/
I have made a header board for STM32L152VD after every restart it takes few seconds for the board to start running. I used the same program to run on STM32L152RC discovery board but I had no problem.
Did the mentioned SPI problem happen on the header board for STM32L152VD or the STM32L152RC discovery board?
Dear Gary, I initialized SPI1 and SPI2 to check if any will work. (both master and independent)
Dear John, I tested the program in both boards.The one I made with STM32L152VD and STM32L discovery both have same problem. I check the SCK and MISO by scope while not connected to slave. Is it necessary to connect to slave in SPI while checking by scope?
No much use looking at the MISO signal without a slave. This signal is Master In, Slave Out. So driven by the slave.
It's the MOSI you want to look at - Master Out, Slave In. But then you don't want to send 0xFFFF since that doesn't give you any nice action on the pin.
The clock signal is always owned by the master and should always play when the master tries to send - no need for any slave connected.
Dear Per, You are right. It was a mistake in typing. I am expecting to see signals on SCK and MOSI.
As I see the following piece of code has been repeated many times by developers the same in the web. I surprise Y it not works in my discovery board! I expect to see the signals in scope but I see nothing.
void SPI_RCC_Configuration() { RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOB,ENABLE); RCC_APB1PeriphClockCmd(RCC_APB1Periph_SPI2,ENABLE); } void SPI_GPIO_Configuration(void) { GPIO_InitTypeDef GPIO_InitStruct; GPIO_InitStruct.GPIO_Pin = GPIO_Pin_13 | GPIO_Pin_14|GPIO_Pin_15; GPIO_InitStruct.GPIO_Speed = GPIO_Speed_40MHz; GPIO_InitStruct.GPIO_Mode = GPIO_Mode_AF; GPIO_InitStruct.GPIO_OType=GPIO_OType_PP; GPIO_Init(GPIOB, &GPIO_InitStruct); GPIO_InitStruct.GPIO_Pin = GPIO_Pin_12; GPIO_InitStruct.GPIO_Mode = GPIO_Mode_OUT; GPIO_InitStruct.GPIO_OType=GPIO_OType_PP; GPIO_Init(GPIOB, &GPIO_InitStruct); GPIO_SetBits(GPIOB,GPIO_Pin_12); } void SPI_Configuration(void) { SPI_InitTypeDef SPI_InitStruct; SPI_RCC_Configuration(); SPI_InitStruct.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_8; SPI_InitStruct.SPI_Direction= SPI_Direction_2Lines_FullDuplex; SPI_InitStruct.SPI_Mode = SPI_Mode_Master; SPI_InitStruct.SPI_DataSize = SPI_DataSize_8b; SPI_InitStruct.SPI_CPOL = SPI_CPOL_Low; SPI_InitStruct.SPI_CPHA = SPI_CPHA_1Edge; SPI_InitStruct.SPI_NSS = SPI_NSS_Hard; SPI_InitStruct.SPI_FirstBit = SPI_FirstBit_MSB; SPI_InitStruct.SPI_CRCPolynomial = 7; SPI_Init(SPI2, &SPI_InitStruct); SPI_GPIO_Configuration(); SPI_SSOutputCmd(SPI2, ENABLE); SPI_Cmd(SPI2, ENABLE); }
//MAIN.C #include "stm32l1xx.h" #include "clock.h" #include "spi_driver.h" int main(void) { int i; SystemCoreClockSetHSI(); SPI_RCC_Configuration(); SPI_Configuration(); SPI_GPIO_Configuration(); while(1) { SPI2->DR = 1; //sending 1 as data for(i=0;i<100000;i++) __nop(); } return 0; }
Why would SPI_GPIO_Configuration be called twice? Once in the SPI_Configuration Function and once in the main() function.
I was looking for SPI code for your board but am not finding a example. On the STM website I downloaded the FW for your board.
at this location at the bottom of the page: www.st.com/.../PF260821
The do not have a SPI example for the discovery board. They do have other examples.
The Nucleo board has a SPI example that compiles. The code is different in many ways from the above code.
Maybe something here my.st.com/.../Flat.aspx
google
SPI problem with hardware NSS management (no text)
