The problem is similar to http://www.keil.com/forum/9257/ . I don't know whether it was solved.
when I call osSemaphoreWait(), the returned value is 0xFFFFFFFF (-1) , which is happened when I use hardware timer independently. The code is showing below,
int32_t sem; osSemaphoreId rl_sem[1]; osSemaphoreDef(sem_0); //user thread 1 Thread() { rl_sem[0]=osSemaphoreCreate(osSemaphore(sem_0),1); while(1) { ... sem = osSemaphoreWait(rl_sem[0],0); printf("sem=%d",sem); //sem normally should be 1, but here it is 0xFFFFFFFF, ie, -1 } } //CAN ISR CAN_IRQHandler() { ... osSemaphoreRelease(rl_sem[0]); } //timer ISR Timer_Callback() { // nothing to do with semaphore }
your advice is much appreciated!
There is no generic problem with semaphores CMSIS-RTOS RTX. Two things that you might verify.
Does this line return a proper ID?
What is the return value of osSemaphoreRelease(rl_sem[0]) in the CAN_IRQHandler()?
yeah,the returned of osSemaphoreCreate is ok, for when no hardware time is used, it works normally. the return value of osSemaphoreRelease(rl_sem[0]) is 0,which means osOK.
Just when I use hardware timer, the return value of osSemaphoreWait is -1.
My cpu is MK64F12,and I use PIT timer. thank you!
Besides, if I set the timer period too small ,like 1ms, then other threads don't work anymore.
I use the hardware timer independently, RTX timer tick is 1000us or 100us which I both tried. The cpu clock is 120MHz.
what should I do , if a fast hardware counter is needed in CMSIS-RTX ? thank a lot.
sorry, I find I use "printf" in Timer IRQ, that resulted in the second problem. But semaphore problem is still not solved.
now, I find the problem, I look into the source code, and osSemaphoreWait is not allowed in ISR, so it returns -1. Thank you!
