I am working on CAN peripheral in LPC2368 controller.I am testing the CAN peripheral in Acceptance filter ON mode with 11-bit Standard Explicit identifier.
Tested Following conditions
EXP_STD_ID = 0x400;
CAN_MEM_BASE = 0xE0038000;
1. For Lower boundary
address =0;
CAN_SFF_SA = address;
i =1;
ID_low = (i << 29) | ((EXP_STD_ID) << 16);
ID_high = ((i+1) << 13) | ((EXP_STD_ID) << 0);
*((volatile DWORD *)(CAN_MEM_BASE + address)) = ID_low | ID_high;
address += 4;
2. For Upper boundary
i =0;
Above Two conditions are working fine,but when i try to include both lower and upper boundaries in CAN channel 2,it's not working
ID_high = (i << 13) | ((EXP_STD_ID) << 0);
I can see you set a value for CAN_SFF_SA. But where do you update the other indices? The explicit standard frame filter processing is all entries from CAN_SFF_SA and up to CAN_SFF_GRP_SA - and the processor does binary subdivision when processing the table so it needs the entries sorted and needs to know where the individual tables ends so it knows how many entries of each type that are stored in the filter RAM.
Another thing - are you making sure the acceptance filter is off or in bypass mode when you try to write to the lookup table?
Hi Per Westermark,
Thanks for your response,
Actually my routine is like this
GRP_STD_ID = 0x300
EXP_EXT_ID = 0x100000
CAN_SFF_GRP_SA = address;
ID_low = (i << 29) | (GRP_STD_ID << 16);
ID_high = ((i+1) << 13) | (GRP_STD_ID << 0);
CAN_EFF_SA = address;
ID_low = (i << 29) | (EXP_EXT_ID << 0);
*((volatile DWORD *)(CAN_MEM_BASE + address)) = ID_low;
CAN_EOT = address;
While writing the Look uptable RAM memory Acceptance filter is in OFF mode
