Evalboard MBC4300, SPIFI
I would like to use the SPIFI memory (S25FL032) of the MBC4300 Eval board from my application.
In the software packs I only find CMSIS Driver/Flash (API) for AT45DB642D. I assume (but did not test) that this driver would not be compatible to the S25FL032. Is the required driver somewhere available?
On lpcware.com I found a Spifi-driver for LPC4300 that supüports htr required device (and many more) but I don't think (but also not verified) that this is not a CMSIS driver which is compatible to the file system middleware which I also would like to use.
Are there any plans that keil middleware supports the spi-flah of their evalboard in the near future?
Thank you
  • Hi,
    the S25FL032 has a size of 4MB, which is big for program code and constants but which is quite small for a files system compared to xGB SD-cards. Because probably only very few customers are interested to run a file system in this small SPIFI Flash, we did not implement CMSIS drivers yet.
    However if you want to do this, you could do this by modifying the driver for the AT45DB642D. You could set up a project with the embedded file system and the AT45DB642D/SPI and then you could exchange the functions in this driver (AT45DB642D.c / SPI_LPC43xx.c) to access the SPIFI Flash. Of course you can also rename all these files.
    Also the flash sectors need to be defined in the header file (AT45DB642D.h). The S25FL032 has 64 x 64K sectors. You can look into our ULINK flash algorithm for the S25FL032 in the folder C:\Keil\ARM\Flash\LPC18xx43xx_S25FL032. There, we are using the LPC libraries and I guess you can take out some code fragments to initialize, erase and program the SPFI Flash.
    Regards
    Hans Schneebauer
  • Hi,
    thank you for this advice.
    When I take the AT45DB642D.c file and replace the functions to access the SPI-Flash S25FL032 (I would use the lib/source from LPCware.com), can I then use the embedded filesystem by simply selecting the correct drive letter?
    4MByte is small compared to SD-Cards with several GBytes, but it is big compared to I2C-EEprom that I want to replace.
    The S25FL032 has a sector size of 64kbyte, but erase size is 4kbyte. In a next step I want to swap to S25FL132 which has a sector size of 4kbyte (and also erase size of 4kbyte).
    I know the fatfs requires 512 byte sectors.
    Does the embedded file system accept this 4kbyte erase sector size?
    I'm sure it's documented somewhere but I did not look for it.
    Maybe you could give me an advice:
    It seems that the existing CMSIS SPI driver does not support the SPIFI mode.
    Would it be "better" to implement a CMSIS SPIFI driver first and use this to implement a S25FL driver, or it it "OK" to mix the device-specific code of SPI-Flash and the SPIFI-funcion?
    Thank you.
