We currently used the version 5.10 of uVision in our projects. Today we did some tests with the new release version 5.15. On my personal system the new version works as expected, but on a second system the compile time for one of our projects raised from 20 seconds up to more than 2 minutes. Is this a known issue? What could be the cause for this behavior?
Regards Adrian
A route cause for slow compiler performance could be Browse Information. When this is enabled under Options - Output the compiler can be slower (when the header files are extensive).
Wasn't it interfering antivirus software that made the compiler extremely slow for another user not too long ago?
Minor update: The version 5.14 works also as expected. It is something new with version 5.15.
Well AV software can be a huge drag on file access performance. The compilers have also become sloths.
"On my personal system the new version works as expected, but on a second system the compile time for one of our projects raised from 20 seconds up to more than 2 minutes"
So you have the same version performing differently on different machines; surely this points to an issue with the 2nd machine - not with the software?
It was not my intention to blame uVision, but we have a problem with uVision and this is the place we are searching for hints and solutions for it. Maybe other users can profit from the found solution.
Actually a hint from other users already solved the issue. It was the Anti Virus software that caused the slow compile performance with uVision 5.15. By excluding the uVision folder the compile time returned to normal values.
Thanks to all users for there hints.
