How do I compile and execute relocatable code on an ARM Cortex M0 chip using Keil? Which are the places that I change the address? Please point me towards more information. The normal code I have runs well without making it relacatable. So far I've made the following changes: In "Options for Target": 1)In the "Target" tab, modified the IROM1 starting address from 0 to 0x8000. 2)In the "C/C++" tab, checked the "Read-only Position Independent" box. 3)In the "Linker" tab, checked the Make RW Sections Position Independent" box. The "R/O Base" is set at 0x00000000 by default and not able to modify it. The code builds well but the code does not execute.
My Final Objective is as follows: The code reads a file (bin or hex) in the external flash and writes it into the on-chip flash. The on-chip flash should always have 2 codes on it but only the latest will be run. This will allow me to check if the code was written correctly on the on-chip flash. If not then I can revert to the earlier code. Thanks
Your code that copies the vector table to RAM will need to do relocation based on the address which the code is placed.
You'll need to evaluate how your specific M0 implements the shadowing of RAM at address 0x00000000.
If so, have you read this: http://www.keil.com/demo/limits.asp
