I have been regularly programming my chip with a J-Link LITE CortexM programmer. I am using uVision 5.1.4.0.0. I try to run the debugger and get the error "No ULINK device found". I can see the device in the device manager. I can also program a hex file to the device using Nordic's nRFgo Studio Program. I believe it and the driver are ok, it is just uVision is having an issue with it. I am running windows xp. Do you have any suggestions so I can fix this?
Thank You, Glenn
I found the issue. The incorrect programmer was selected in the debug tab. uVision had locked up and crashed the last time I tried to close it.
