is there a possibility to trigger the build process from external? E.g. using command line or an external program? The build process should be done in the already opened UV5 window and it should not close the window when finished.
Regards
Michael
You can use the uVision Socket interface for that. See: http://www.keil.com/appnotes/docs/apnt_198.asp
There is a UVSC_Tester.exe included in the download ZIP file that allows you to trigger commands. You can use the source code as template for your own application.
