interfacing hcsr04 ultrasonic sensor with lpc1768
hi
I was working with interfacing of hc sr04 ultrasonic sensor with lpc1768 so as to display the distance from an obstacle to the sensor on an LCD display in centimeters ..
there were no errors in the code, but distance is not being varied its showing always as 0 cm..
i could not find the problem.. i'm sure that sensor is in good condition
i'm attaching the code
Microcontroller: LPC1768-Cortex M3
Clock: 12mhz
Compiler Keil uVision 4
#include "lpc17xx.h"
#include "type.h"
#include "delay.h"
#include "lcd.h"                      //header file to program LCD
#define US_PORTCLR LPC_GPIO0->FIOCLR
#define US_PORTSET LPC_GPIO0->FIOSET
#define US_DDR     LPC_GPIO0->FIODIR
#define US_PIN     LPC_GPIO0->FIOPIN
#define US_ECHO   5                // pot 0 5th pin for echo
#define US_TRIG 6             // p0.6 for trigger
 #define US_ERROR 0xffff
 #define  US_NO_OBSTACLE 0xfffe
uint32_t d;
uint16_t getPulseWidth()
                        uint32_t i,result;
       //Wait for the rising edge
       for(i=0;i<600000;i++)
          if(!(US_PIN & (1<<US_ECHO))) continue; else break;
       if(i==600000)
          return 0xffff; //Indicates time out
       //High Edge Found
       //Setup Timer1
      LPC_SC->PCONP |= 1 << 1;                                         //Power up Timer 0
            LPC_SC->PCLKSEL0 |= ( 1 << 2)|(1<<3);                        // Clock for timer = CCLK /8 -->12000000/8hz
                         LPC_TIM0->TC=0x00000000; // init counter
        LPC_TIM0->TCR |= 1 << 1;       // reset timer
                         LPC_TIM0->TCR |= 1 << 0;                                      // Start timer
       //Now wait for the falling edge
          if(US_PIN & (1<<US_ECHO))
             if((LPC_TIM0->TC) > 60000) break; else continue;
          else
           break;
       if(i==600000)
       //Falling edge found
       result=(LPC_TIM0->TC); //STORE COUNT IN RESULT
       //Stop Timer
       LPC_TIM0->TCR |= 0 << 0;
       if(result > 60000)
          return 0xfffe; //No obstacle
       else
          return (result>>1);
int main(void)
         uint16_t r;
         LPC_PINCON->PINSEL0|=(0<<10)|(0<<11)|(0<<12)|(0<<13);// MAKING P0.5,6 AS GPIO
        SystemInit();
  lcd_init();                                   //initialization of LCD
         delay(500);
  lcd_gotoxy(0,0);                              //function to move the cursor position to (0th row & 5th column )
  lcd_string("Hc sr04 test"); //function to display a string
         delay(500);
  while(1)
                //Set Ultra Sonic Port as out
         US_DDR|=(1<<US_TRIG);
         delay_us(10);
         //Give the US pin a 15us High Pulse
         US_PORTSET|=(1<<US_TRIG);   //High
        delay_us(15);
         US_PORTCLR|=(1<<US_TRIG);//Low
         delay_us(20);
        //Now make the pin input
         US_DDR&=(~(1<<US_ECHO));
       //Measure the width of pulse
         r=getPulseWidth();
         //Handle Errors
         if(r==US_ERROR)
            lcd_clear();
               lcd_gotoxy(0,0);
               delay_us(100);
              lcd_string("error");
         else  if(r==US_NO_OBSTACLE)
            lcd_gotoxy(0,0);
               delay_us(100);
               lcd_string("clear");
         else
            d=(r/58.0); //Convert to cm
            lcd_gotoxy(1,0);
               lcd_string("d=");
               delay_us(100);
                lcd_gotoxy(1,4);
               lcd_showvalue(d);
              delay_ms(50);
              lcd_gotoxy(1,7);
              lcd_string("cm");
            delay_ms(100);
  •          LPC_PINCON->PINSEL0|=(0<<10)|(0<<11)|(0<<12)|(0<<13);// MAKING P0.5,6 AS GPIO
    You want to _set_ zero bits? |= can only set - never clear.
    Note also that the processor has a capture function - it can itself copy the current timer value to a capture register when the external pin changes state.
    You say you can't find your problem, but you have no printouts and nothing in your text that indicates that you have done any debugging. Have you seen the sensor pin change from low to high? Change from high to low?
    Have you verified that your timer ticks in expected speed - does it take 10 seconds for the timer to tick 10 seconds of ticks?
    Exactly what have you done to figure out what works and what doesn't work?
  • hey i am building the same project using the same sensor but my processor is lpc2148.
    So can u plz provide me the source code for the same.
  • "So can u plz provide me the source code for the same."
    The OP has already posted his non-working code for a 17xx.
    If you really want to hand in "stolen" code - why not then rewrite the code from a 17xx to a 21xx and at the same time fix the bug? Or did you expect the OP or someone else to rewrite the code and hand you, so you have something to hand in to your teacher?
  • hi,
    I'M JUST A BEGINNER ON ARM AND I'M ALSO TRYING TO FIX THE BUG..YOU CAN DERIVE THE CODE,WHICH YOU ARE IN NEED OF, FROM THE ABOVE ONE OF MINE..JUST NEED TO CHANGE THOSE REGISTER NAMES WHEREVER NECESSARY ..
    THANK YOU.
