I am Johnson Philip, Electrical Engineer working in lighting sector.I am from Sydney, Australia. Currently, I am doing a research on power-line based lighting control in association with a prestigious Australian Lighting company.
Most of our light fittings are for industrial purposes such as mining, oil &gas, food processing etc. I 'll explain to you what we are looking for.
Lighting control unit>>"LON WORKS">>>Segment Controller (to be installed with supervisory interfacing s/w) >>>>TCP/IP>>>>>>Human Machine Interfaces
we would like to design our own lighting controller unit (to be fitted inside the light fitting along with the 0-10 V/ DALI ballast). In that case , if I am correct, the system inside the controller will look like as follows,
From power line>>>coupling circuit>>>digital interfacing circuit (?)>>>>PL 3120 Smart Transceiver>>>> EXTERNAL INTERFACING CKT to control 1-10 V/DALI ballast>>>>Existing ballast.
EXTERNAL INTERFACING CKT to control 1-10 V/DALI ballast: this what we would like to know , how to interface with our existing ballast (Xitanium, Philips). Or else how to give 1-10 V dimming signal to our existing Philips electronic drive.
I am looking forward to hearing from you very soon.
Johnson Philip
Electrical Engineer
Then that'd be echelon.com, not keil.com.
Thanks for reveling your design. We are on the project. You may soon see a competitor design in the market. All the Best.
