I have an annoying issue, as I am not able to set up trace to work.
I am using Keil MDK-lite v5.12, standard STM32f4-Discovery board with stm32f407vgt6 aboard, have updated all firmware, software packs are latest version, SWV set up as necessary and RTX_Blinky5 example project is running with Thread & System window responding but, nothing appears on Trace Records window nor Logic analyzer or Event Viewer. also at the bottom of the UV appears "Trace: no synchronization"
Thanks everyone for your insight!
I have exactly the same problem with exactly the same setup. Did you find a solution? If I do I will post.
