WHEN I TRY TO DOWNLOAD CODE INTO TARGET BOARD BY ULINK2 JTAG DEBUGGER FOLLOWING ERROR MESSAGE IS COMING "NO ULINK DEVICE FOUND" I AM USING KEIL4 uVERSION IDE FOR PROGRAMMING WITH MCB2929 KEIL DEVELOPMENT BOARD
Does the ULINK show up in Device Manager?
Does the ULINK and chip on the board show up in the Debug configuration pane?
Does your CAPS LOCK key not work?
Yes it is showing in my device manager
No it is showing that "No ULINK device found"
Ok, and what version of the driver does Device Manager indicate it is using?
For that matter, what version of Windows are you using, and what version of uV4 is this?
Has this ULink2 been usable on other systems? Have you updated the firmware on it recently? Is it configured suitably for the version of uV4 you are using?
C:\Keil474\ARM\ULINK C:\Keil474\ARM\ULINK\Utilities\UL2_Configure.exe C:\Keil474\ARM\ULINK\Utilities\UL2_Upgrade_V201.exe
http://www.keil.com/support/man/docs/ulink2/ulink2_boot_mode.htm
http://www.keil.com/support/docs/3613.htm
