How to create a directory on Flash by RL_FS?
I need two directories to save some data.One directory save runing log and another save my last program image.
I try to use following code to create ABC directory .but faild.
hFile = fopen("S:\\ABC\\1.txt","w");
if(hFile)   //In herer ,hFile = 0
        fclose(hFile);
        fdelete("S:\\ABC\\1.txt");
How to create a directory?Who can help me to solve it .
thanks !
  • It's a bit interesting that the Keil documentation has examples that shows of a path used when creating a file will place the file in that directory - but their function reference doesn't document any function for creating or removing any sub-directories.
    The fopen() documentation contains the information:
    "filename can include a path. If the path does not exist, all subfolders are created."
    So it sounds like your code should create the subdirectory and then the file on a SPI file system.
  • Thanks for your replay.
    I found the problem finally.
    First, i wrote "w" in uppercase.so the hFile is invalid.
    Second,SPI Flash base on EFS.
    RL-FlashFS » Embedded File System » Limitations contains the information:
    Directories or folders are not supported.
    File names are preprocessed to remove the path information for non-FAT file systems.
    So i can't create any subdirectory on a SPI file system.
