Hello all I just working on project using encoder interface but as much as search for example for encoder interface for stm32 I find less I want a sample that use interrupt and micro encoder capability not software solution that can give me direction count and speed but there nothing use full that I can find in reference manual or timers application note or even micro manual the micro I just using is stm32l152rbt6 I find confining alternate function for encoder interface but there no evidence of interrupt handler for using that Please help me if you can
Part of code that I just use till now
void MX_GPIO_Init(void) { GPIO_InitTypeDef GPIO_InitStruct;
/** Configure pins as * Analog * Input * Output * EVENT_OUT * EXTI PA8 ------> SYS_MCO */
/*Enable or disable the AHB peripheral clock */ RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOB|RCC_AHBPeriph_GPIOA, ENABLE);
/*Configure GPIO pin : PB */ GPIO_InitStruct.GPIO_Pin = GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14|GPIO_Pin_15; GPIO_InitStruct.GPIO_Mode = GPIO_Mode_OUT; GPIO_InitStruct.GPIO_OType = GPIO_OType_PP; GPIO_InitStruct.GPIO_PuPd = GPIO_PuPd_NOPULL; GPIO_InitStruct.GPIO_Speed = GPIO_Speed_40MHz; GPIO_Init(GPIOB, &GPIO_InitStruct);
/*Configure GPIO pin : PA */ GPIO_InitStruct.GPIO_Pin = GPIO_Pin_8; GPIO_InitStruct.GPIO_Mode = GPIO_Mode_OUT; GPIO_InitStruct.GPIO_OType = GPIO_OType_PP; GPIO_InitStruct.GPIO_PuPd = GPIO_PuPd_NOPULL; GPIO_InitStruct.GPIO_Speed = GPIO_Speed_400KHz; GPIO_Init(GPIOA, &GPIO_InitStruct);
/*Configure GPIO pin alternate function */ GPIO_PinAFConfig(GPIOA, GPIO_PinSource8, GPIO_AF_MCO);
/** I2C1 GPIO Configuration PB6 ------> I2C1_SCL PB7 ------> I2C1_SDA */
/*Enable or disable the AHB peripheral clock */ RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOB, ENABLE);
/*Configure GPIO pin : PB */ GPIO_InitStruct.GPIO_Pin = GPIO_Pin_6|GPIO_Pin_7; GPIO_InitStruct.GPIO_Mode = GPIO_Mode_OUT; GPIO_InitStruct.GPIO_OType = GPIO_OType_PP; GPIO_InitStruct.GPIO_PuPd = GPIO_PuPd_NOPULL; GPIO_InitStruct.GPIO_Speed = GPIO_Speed_400KHz; GPIO_Init(GPIOB, &GPIO_InitStruct);
/*Configure GPIO pin alternate function */ GPIO_PinAFConfig(GPIOB, GPIO_PinSource6, GPIO_AF_I2C1);
/*Configure GPIO pin alternate function */ GPIO_PinAFConfig(GPIOB, GPIO_PinSource7, GPIO_AF_I2C1);
/** TIM2 GPIO Configuration PA0-WKUP1 ------> TIM2_CH1_ETR PA1 ------> TIM2_CH2 */
/*Enable or disable the AHB peripheral clock */ RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA, ENABLE);
/*Configure GPIO pin : PA */ GPIO_InitStruct.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1; GPIO_InitStruct.GPIO_Mode = GPIO_Mode_OUT; GPIO_InitStruct.GPIO_OType = GPIO_OType_PP; GPIO_InitStruct.GPIO_PuPd = GPIO_PuPd_NOPULL; GPIO_InitStruct.GPIO_Speed = GPIO_Speed_400KHz; GPIO_Init(GPIOA, &GPIO_InitStruct);
/*Configure GPIO pin alternate function */ GPIO_PinAFConfig(GPIOA, GPIO_PinSource0, GPIO_AF_TIM2);
/*Configure GPIO pin alternate function */ GPIO_PinAFConfig(GPIOA, GPIO_PinSource1, GPIO_AF_TIM2);
/** USART3 GPIO Configuration PB10 ------> USART3_TX PB11 ------> USART3_RX */
/*Configure GPIO pin : PB */ GPIO_InitStruct.GPIO_Pin = GPIO_Pin_10|GPIO_Pin_11; GPIO_InitStruct.GPIO_Mode = GPIO_Mode_OUT; GPIO_InitStruct.GPIO_OType = GPIO_OType_PP; GPIO_InitStruct.GPIO_PuPd = GPIO_PuPd_NOPULL; GPIO_InitStruct.GPIO_Speed = GPIO_Speed_400KHz; GPIO_Init(GPIOB, &GPIO_InitStruct);
/*Configure GPIO pin alternate function */ GPIO_PinAFConfig(GPIOB, GPIO_PinSource10, GPIO_AF_USART3);
/*Configure GPIO pin alternate function */ GPIO_PinAFConfig(GPIOB, GPIO_PinSource11, GPIO_AF_USART3);
void RCC_Configuration(void) { /* TIM2 clock enable */ RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE);
/* GPIOA clock enable */ RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA, ENABLE); }
void TIM2_Configuration(void) { TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
TIM_TimeBaseStructure.TIM_Prescaler = 0; TIM_TimeBaseStructure.TIM_Period = 0xFFFFFFFF; // Maximal TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1; TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure);
// TIM_EncoderMode_TI1: Counter counts on TI1FP1 edge depending on TI2FP2 level. TIM_EncoderInterfaceConfig(TIM2, TIM_EncoderMode_TI1, TIM_ICPolarity_Rising, TIM_ICPolarity_Rising);
TIM_Cmd(TIM2, ENABLE);
Wall of code, non-sense, ...
If you just want to read encoder position, read TIMx->CNT, ideally use a 32-bit counter, and channel 1 and 2 via pins that map there, see the Data Sheet for options/availability.
Use Update, or assorted CC Channel Compare (CC) interrupts to catch, or advance/retard counts you wish to get signalled.
