enumeration with error when a value is used twice
Hello everyone,
is it possible to test an enum for each value just appearing once.
Example:
enum foo
   BAR = 0,
   BAZ = 0
Is it possible to create an error or warning with this?
Thanks for your answers
Alexander
  • But there is nothing erroneous about it as far as the language is concerned - so nothing to report.
  • I just wondered if there was any compiler specific flag.
  • Just as there should be compiler flags to warn if any integer gets the value 123456?
    If you want non-overlapping enumeration values, the natural way is to write:
    enum {
        Ben,
        John,
        Charlie,
    or with an initial start value:
    enum {
        Red = 1,
        Green,
        Blue
    If you on the other hand decides to explicitly assign a numeric value to multiple entries, then it's 100% your task to decide what values to assign. And consider the implications of the selected numerical values.
    The language do not care about overlapping numerical values, just as preprocessor-based code:
    #define VOLTAGE 1
    #define CURRENT 2
    #define TEMPERATURE 3
    wouldn't care if two #define expands to the same numerical value.
    If you have a problem with overlapping numerical values, then the obvious choice is to stop assign explicit values and let the compiler auto-enumerate.
