uVision batch file doesn't work
my problem is the same as described here:
http://www.keil.com/forum/14024/using-batch-file-to-build-project/
the created batch file doesn't work. I guess it would, but the mentioned *.__i files get deleted after the build from within uVision (btw. ARM MDK 5.14, using STM32Fxxx).
I know it's possible to call UV.exe to build the project, but that doesn't work for me because I need to redirect compiler/linker output to a different program.
Is there a solution for this problem now?
regards, Christoph
