Compiler Migration error
I have a working project at uVision 5.01 and ARMCC 5.03.0.76.
I have upgraded the uVision at 5.14 and ARMCC to 5.05 and I am getting some Internal faults.
I have kept the new uVision GUI (5.14) and replaced the compiler with 5.03 and worked fine again.
I have isolated the code rows that produce the internal errors. The problem is when I am trying
to assign an integer value from a struct member to another member of another struct.
This is happening only at integer values not chars, shorts.
I have also created a new project with the new GUI and added the old files but
I got the same errors.
But when I created a new project and just created a single struct and
assigned an integer member then it worked fine.
Any ideas?
Thanks in advance.
  • Hello Mike,
    can you please contact support regarding this issue: support.intl@keil.com
    Kind regards,
    Christopher
  • I believe it is a "packed" issue.
    I am giving you an example:
    This code produces internal error.
    typedef volatile __packed struct{
            unsigned int    VA;
            unsigned int    VB;
            unsigned int    VC;
            unsigned int    VD;
            unsigned int    AWV;
            unsigned int    AWoutV;
            unsigned short  S;
            unsigned char   aa1;
            unsigned short  aa2;
            unsigned int    TVA;
    }ZONE;
            unsigned int  VA;
            unsigned int  AWV;
            unsigned int  TVA;
    }REPORT;
    int main (void){
            ZONE z;
            REPORT myReport;
            myReport.VA     = z.VA;
            myReport.AWV    = z.AWV;
            myReport.TVA    = z.TVA;
            return 0;
    This code does not produce any error.
            unsigned int    VA;
            unsigned int    VB;
            unsigned int    VC;
            unsigned int    VD;
            unsigned short  S;
            unsigned char   aa1;
            unsigned short  aa2;
            unsigned int    TVA;
            unsigned int    AWV;
    }ZONE;
            unsigned int  VA;
            unsigned int  AWV;
            unsigned int  TVA;
    }REPORT;
    int main (void){
            ZONE z;
            REPORT myReport;
            myReport.VA     = z.VA;
            return 0;
    The only difference is at the variable order.
    Any ideas?
  • Again, I think that support should have a look into this.
    Kind regards,
    Christopher
  • When you contact support - remember to also include the actual error messages.
