Migrate RL-FLASHFS to HY27UF081G2A
Recently,I am trying to migrate RL-FLASHFS to my board,which is composed stm32f103zet6 and hy27uf081g2a. But I failed.
part of code :
/* NAND Page Layout Definition */  //These may be wrong,and I don't know how to change
#define ON_POS_LSN      2
#define ON_POS_COR      1
#define ON_POS_BBM      0
#define ON_POS_ECC      8
#define ON_SECT_INC   512
#define ON_SPARE_OFS 2048
#define ON_SPARE_INC   16
 *      NAND driver prototypes
static U32 Init         (NAND_DRV_CFG *cfg);
static U32 UnInit       (NAND_DRV_CFG *cfg);
static U32 PageRead     (U32 row, U8 *buf, NAND_DRV_CFG *cfg);
static U32 PageWrite    (U32 row, U8 *buf, NAND_DRV_CFG *cfg);
static U32 BlockErase   (U32 row, NAND_DRV_CFG *cfg);
  NAND Device Driver Control Block
void NAND_Init(void)
FSMC_NANDCmd(FSMC_Bank2_NAND, ENABLE);
void NAND_DeInit(void)
        FSMC_NANDCmd(FSMC_Bank2_NAND, DISABLE);
uint32_t NAND_ReadPage(uint32_t Address, uint8_t *pBuffer, NAND_DRV_CFG *cfg)
        uint32_t index = 0x00,  addressstatus = NAND_VALID_ADDRESS;
        uint32_t status = NAND_READY, size = 0x00;
        if(Address++ > (NAND_MAX_ZONE*NAND_ZONE_SIZE*NAND_BLOCK_SIZE))
                addressstatus = NAND_INVALID_ADDRESS;
                return (addressstatus);
        /*!< Page Read command and page address */
        *(__IO uint8_t *)(Bank_NAND_ADDR | CMD_AREA) = NAND_CMD_READ0;
    *(__IO uint8_t *)(Bank_NAND_ADDR | ADDR_AREA) = ADDR_1st_CYCLE(Address);
    *(__IO uint8_t *)(Bank_NAND_ADDR | ADDR_AREA) = ADDR_2nd_CYCLE(Address);
    *(__IO uint8_t *)(Bank_NAND_ADDR | ADDR_AREA) = ADDR_3rd_CYCLE(Address);
    *(__IO uint8_t *)(Bank_NAND_ADDR | ADDR_AREA) = ADDR_4th_CYCLE(Address);
    *(__IO uint8_t *)(Bank_NAND_ADDR | CMD_AREA) = NAND_CMD_READ_TRUE1;
    /**wait for ready**/
    while( GPIO_ReadInputDataBit(GPIOD, GPIO_Pin_6) == 0 );
    /*!< Calculate the size */
    size = cfg->PageSize;
    /*!< Get Data into Buffer */
    for(; index < size; index++)
      pBuffer[index]= *(__IO uint8_t *)(Bank_NAND_ADDR | DATA_AREA);
        status = NAND_GetStatus();
        return (status | addressstatus);
uint32_t NAND_WritePage(uint32_t Address, uint8_t *pBuffer, NAND_DRV_CFG *cfg)
            /*!< Page write command and address */
            *(__IO uint8_t *)(Bank_NAND_ADDR | CMD_AREA) = NAND_CMD_WRITE0;
            /*!< Write data */
              *(__IO uint8_t *)(Bank_NAND_ADDR | DATA_AREA) = pBuffer[index];
            *(__IO uint8_t *)(Bank_NAND_ADDR | CMD_AREA) = NAND_CMD_WRITE_TRUE1;
            /**wait for ready singal**/
            /*!< Check status for successful operation */
uint32_t NAND_EraseBlock(uint32_t Address)
        uint32_t data = 0xff, status = NAND_ERROR;
        *(__IO uint8_t *)(Bank_NAND_ADDR | CMD_AREA) = NAND_CMD_ERASE0;
        *(__IO uint8_t *)(Bank_NAND_ADDR | CMD_AREA) = NAND_CMD_ERASE1;
        /* Read status operation ------------------------------------ */
    return(NAND_GetStatus());
        cfg->PgLay->Pos_LSN  = ON_POS_LSN;
        cfg->PgLay->Pos_COR  = ON_POS_COR;
        cfg->PgLay->Pos_BBM  = ON_POS_BBM;
        cfg->PgLay->Pos_ECC  = ON_POS_ECC;
        cfg->PgLay->SectInc  = ON_SECT_INC;
        cfg->PgLay->SpareOfs = ON_SPARE_OFS;
        cfg->PgLay->SpareInc = ON_SPARE_INC;    /**/
        NAND_Init();
        return RTV_NOERR;
        NAND_DeInit();
        return RTV_NOERR;
        uint32_t status = NAND_READY;
  /* Determine Chip Select from instance number */
        if(cfg->DrvInst == 0)
                status = NAND_ReadPage(row, buf, cfg);
                if(!(status & NAND_READY))
                        return  ERR_NAND_HW_TOUT;
                return  RTV_NOERR;
        else
                return  ERR_INVALID_PARAM;
                status = NAND_WritePage(row, buf, cfg);
                if(!(status&NAND_READY))
                        return  ERR_NAND_PROG;
                return  RTV_NOERR;
        else
                status = NAND_EraseBlock(row);
                if(status !=NAND_READY)
                        return  ERR_NAND_ERASE;
                return  RTV_NOERR;
        else
  • Some define and the function NAND_Init()
    #define FSMC_Bank_NAND     FSMC_Bank2_NAND
    #define Bank_NAND_ADDR     Bank2_NAND_ADDR
    #define Bank2_NAND_ADDR    ((uint32_t)0x70000000)
    #define NAND_PAGE_SIZE             ((u16)0x0800) /* 2K bytes per page w/o Spare Area */
    #define NAND_BLOCK_SIZE            ((u16)0x0040) /* 64x2K bytes pages per block */
    #define NAND_ZONE_SIZE             ((u16)0x0400) /* 1024 Block per zone */
    #define NAND_SPARE_AREA_SIZE       ((u16)0x0040) /* last 64 bytes as spare area */
    #define NAND_MAX_ZONE              ((u16)0x0001) /* 1 zones of 1024 block */
      * @brief  FSMC NAND memory address computation
    #define ADDR_1st_CYCLE(PADDR)       (uint8_t)(0x0)                       /* 1st addressing cycle */
    #define ADDR_2nd_CYCLE(PADDR)       (uint8_t)(0x0)                       /* 2nd addressing cycle */
    #define ADDR_3rd_CYCLE(PADDR)       (uint8_t)(PADDR & 0xFF)              /* 3rd addressing cycle */
    #define ADDR_4th_CYCLE(PADDR)       (uint8_t)((PADDR>>8) & 0xFF)         /* 4th addressing cycle */
    /* FSMC NAND memory data computation */
    #define DATA_1st_CYCLE(DATA)       (uint8_t)((DATA)& 0xFF)               /* 1st data cycle */
    #define DATA_2nd_CYCLE(DATA)       (uint8_t)(((DATA)& 0xFF00) >> 8)      /* 2nd data cycle */
    #define DATA_3rd_CYCLE(DATA)       (uint8_t)(((DATA)& 0xFF0000) >> 16)   /* 3rd data cycle */
    #define DATA_4th_CYCLE(DATA)       (uint8_t)(((DATA)& 0xFF000000) >> 24) /* 4th data cycle */
            GPIO_InitTypeDef GPIO_InitStructure;
            FSMC_NAND_PCCARDTimingInitTypeDef  p;
            FSMC_NANDInitTypeDef FSMC_NANDInitStructure;
            RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD | RCC_APB2Periph_GPIOE, ENABLE);
            RCC_AHBPeriphClockCmd(RCC_AHBPeriph_FSMC,ENABLE);
            GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_14 | GPIO_Pin_15 | GPIO_Pin_0 | GPIO_Pin_1 |
        GPIO_Pin_4 | GPIO_Pin_5 | GPIO_Pin_7 | GPIO_Pin_11 | GPIO_Pin_12;
            GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
            GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
            GPIO_Init(GPIOD, &GPIO_InitStructure);
            GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_7 | GPIO_Pin_8 | GPIO_Pin_9 | GPIO_Pin_10
            GPIO_Init(GPIOE, &GPIO_InitStructure);
            GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6;
            GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
            p.FSMC_SetupTime = 0x1;
            p.FSMC_WaitSetupTime = 0x3;
            p.FSMC_HoldSetupTime = 0x2;
            p.FSMC_HiZSetupTime = 0x1;
            FSMC_NANDInitStructure.FSMC_Bank = FSMC_Bank2_NAND;
            FSMC_NANDInitStructure.FSMC_Waitfeature = FSMC_Waitfeature_Enable;
            FSMC_NANDInitStructure.FSMC_MemoryDataWidth = FSMC_MemoryDataWidth_8b;
            FSMC_NANDInitStructure.FSMC_ECC = FSMC_ECC_Enable;
            FSMC_NANDInitStructure.FSMC_ECCPageSize = FSMC_ECCPageSize_2048Bytes;
            FSMC_NANDInitStructure.FSMC_TCLRSetupTime = 0x00;             //CLE low to RE low
            FSMC_NANDInitStructure.FSMC_TARSetupTime = 0x00;        //ALE low to RE low
            FSMC_NANDInitStructure.FSMC_CommonSpaceTimingStruct = &p;
            FSMC_NANDInitStructure.FSMC_AttributeSpaceTimingStruct = &p;
            FSMC_NANDInit(&FSMC_NANDInitStructure);
