I‘m trying to evaluate Keil Embedded Workbench.
I used an STM32 and Kinetis Eval Board with a Segger J-LINK Debugger. On Both I get the Error when I try to Flash the Code (Compiling went without Errors): Error: Flash Downloader failed – “Cortex M3”
The Eval-Boards and the Debugger are working fine with IAR and Rowley Crossworks, so it must be something with Keil.
Any Idea what I could do to avoid the error?
Thanks and regards
Correct selection of SWD or JTAG? Correct selection of Flash Algorithm?
thanks for replay.
The error message is coming, no Matter which port (JTAG or SW) I choose. But auto detection of the device is only working with JTAG.
Programming Algorithm should also be correct STM32 F103 ZE --> STM32F10X High-density Flash Kinetis K60DN512 --> MKxxN 512kB Prog Flash
Regards
