I have some problems when I try to create a project using the code banking technology. Could you provide me a example project by using assembly language?
nope, not till you state the EXACT chip you use as well as what external memory you have connected
Thank you for your reply, I do not use any external chip,the MCU that I want to use is C8051F120. I need a project by using assembly language(not C language). I hope to get your help very much.
The Banking mechanism neither knows nor cares what source language you use.
Have you studied the documentation?
If you're an assembler programmer, you should be used to paying particular attention to fine detail...
"I have some problems..."
How do you expect people to be able help you resolve those problems without knowing what they are?!
SILabs has an appnote on code banking the '120
