Read/Write Variable in Source Code Using the Debug Script
Hi.
I'm just trying to learn how to use the debug script and what I want to do is to modify a variable from the source code, continue to run whatever functions the variable is involved and store a result to a log file. This process will be repeated with different variable values.
Example:
int Square (int x)
  x*x;
int z = 1;
int y = Square(z)
I'll run Square for five times (using breakset) while substituting z with 1, 2, 3, 4, and 5 in each run.
I already know how to do the logging but not the read/modify variable.
An example will be much appreciated.
TIA
