I2C Communication with STM32F3
Hello guys,
I would like to ask for some help concerning I2C communication. I am an amateur regarding this type of communication and struggle making an easy write cycle.
Here are the facts:
-My SDA is on PinA14, SCL is on PinA15.
-The slave's ID is 0xC0, on 7 Bits.
-I would like to write on slaves register 0x80 the data 0x30.
As far as i understood i have to send:
First : Slaves ID
Second : Register adress from my Slave
Third : Data i like to be written on this Register adress
Moreover, i have turned the interrupt when the Adress matched, and when the transfer is completed.
My questions are :
Why dont i receive any interrupt?
Do i get an interrupt when i receive an acknowledge from my slave?
I am using the standart peripheral drivers for stm32f3.
The code is the following:
#include "stm32f30x.h"
void init_I2C()
        I2C_InitTypeDef i2c;
        NVIC_InitTypeDef nvic;
        GPIO_InitTypeDef Gpio;
        I2C_InitTypeDef  I2C;
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_I2C1, ENABLE);
        RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA  ,ENABLE);
        Gpio.GPIO_Pin=GPIO_Pin_15;
        Gpio.GPIO_Mode = GPIO_Mode_AF;
        Gpio.GPIO_OType = GPIO_OType_OD;
        Gpio.GPIO_Speed = GPIO_Speed_50MHz;
        GPIO_PinAFConfig(GPIOA,GPIO_PinSource15,GPIO_AF_4);
        GPIO_Init(GPIOA,&Gpio);
        Gpio.GPIO_Pin = GPIO_Pin_14;
        GPIO_PinAFConfig(GPIOA,GPIO_PinSource14,GPIO_AF_4);
        I2C.I2C_Mode = I2C_Mode_I2C;
        I2C.I2C_OwnAddress1  = 0x00;
        I2C.I2C_Timing = 400000;
        I2C.I2C_Ack = I2C_Ack_Enable;
        I2C.I2C_AcknowledgedAddress = I2C_AcknowledgedAddress_7bit;
        I2C_Init(I2C1,&I2C);
        // Enable Transfer Adress Matched, transfer completed
        I2C_ITConfig(I2C1,I2C_IT_ADDR, ENABLE);
        I2C_ITConfig(I2C1,I2C_IT_TCI,ENABLE);
        // SET ADRESS
        I2C_SlaveAddressConfig(I2C1,0xC0);
        // Transfer direction
        I2C_MasterRequestConfig(I2C1,I2C_Direction_Transmitter);
        // Number of bytes send per Communication.
        I2C_NumberOfBytesConfig(I2C1,2);
        I2C_AutoEndCmd(I2C1,ENABLE);
        nvic.NVIC_IRQChannel = I2C1_EV_IRQn;
        nvic.NVIC_IRQChannelCmd = ENABLE;
        NVIC_Init(&nvic);
int main()
        init_I2C();
        I2C_SendData(I2C1,0x80);
        I2C_Cmd(I2C1,ENABLE);
        I2C_GenerateSTART(I2C1, ENABLE);
        while(1)
void I2C1_EV_IRQHandler()
  // Acknoledge bit received!
        if( I2C_GetFlagStatus(I2C1, I2C_FLAG_ADDR)) // Adressed Matched
                c
                I2C_SendData(I2C1,0x30); // Send the data
        // Reset to 0
        if(I2C_GetFlagStatus(I2C1,I2C_FLAG_TC)) // Transfer completed
                I2C_ClearITPendingBit(I2C1,I2C_IT_STOPF);
