Hi all,
I am using SD Memory interface in SPI mode with LPC1768 and using the keil Flash file system as Memory Card Driver0. The SD Memory used is 512MB/4GB HC complaint.
I have customised the SD_File code of MCB1700 for muy application.
But some times it shows error as "SD/MMC Init Failed" and "Insert memory card and press key".
Please share the example code with LPC1768.
Please suggest to resolve this problem.
Regards, Dnyaneshwar Sahane INDIA
