I wrote a simple bootloader program (doesn't do anything but jump to the application code in flash once a timer expires) and I am having trouble getting rtx to work in the application code. It gets to a point in os_sys_init()'s assembly code where it will stick. If my application without rtx,it do work ok.
I am using the stm32f429zi m4 chip.
This is bootloader code.
static void JumpToApp(void) { if (((*(__IO uint32_t*)ApplicationAddress) & 0x2FFD0000) == 0x20000000) { /* Jump to user application */ m_JumpAddress = *(__IO uint32_t*) (ApplicationAddress + 4); JumpToApplication = (FunVoidType) m_JumpAddress; /* Initialize user application's Stack Pointer */ __set_MSP(*(__IO uint32_t*) ApplicationAddress); __set_PRIMASK(1); JumpToApplication(); } Uart1SendSyc("JumpToApp Failed!\r\n"); }
This is appliction code.
int main(void) { NVIC_SetVectorTable(NVIC_VectTab_FLASH, 0x10000); LED_Init(); while(1) { STM_EVAL_LEDToggle(LED4); } }
this is .s file. ; Vector Table Mapped to Address 0 at Reset AREA RESET, DATA, READONLY EXPORT __Vectors EXPORT __Vectors_End EXPORT __Vectors_Size
What can i do for Vector ? I am sorry for my english level.. I hope you can understand.
I find my mistake. if (((*(__IO uint32_t*)ApplicationAddress) & 0x2FFD0000) == 0x20000000)
The code has mistake.
STM32F429ZI's stack start 0x20000000H size 30000H. So I change code below:
static void JumpToApp(void) { UINT32 addr = (*(__IO uint32_t*)ApplicationAddress); addr = addr & 0x1FFFFFFF; if (addr < 0x30000)//check stack addr { /* Jump to user application */ m_JumpAddress = *(__IO uint32_t*) (ApplicationAddress + 4); JumpToApplication = (FunVoidType) m_JumpAddress; /* Initialize user application's Stack Pointer */ __set_MSP(*(__IO uint32_t*) ApplicationAddress); __set_PRIMASK(1); JumpToApplication(); } Uart1SendSyc("JumpToApp Failed!\r\n"); }
That is ok.
