MDK v5 ENC28J60 Driver
Hi!
I have faced a problem with the new MDK 5 environment. On MDK v4 I was using Keil RTX and RL-TCPnet as the IP stack combined with various Ethernet adapters. I have written the drivers mostly by myself, because it was very easy. There are only 3 functions to implement for RL-TCPnet to work fine. Mostly I use the wide spreaded ENC28J60 adapter that is connected over SPI.
Now I want to move to MDK5 and I know I need to rewrite all my code for the new pack idea structure. But there is no possibility to write own drivers for devices that are not supported by Keil...
So now my question. Does someone have a working driver for ENC28J60 for the new MDK5, or some links/information where can I learn how to write my own drivers for MDK5?
Many thanks in adevance.
  • Hi Chris/Eryk
    Any update on the enc28j60 driver for MDK 5.0?
    I have actually done the work of analyzing sample drivers. and also faked my own driver to be installed in KEIL (I didn't find the document how to "create and package and publish your own driver!). But far away from to get it working.
  • Hi Chris/Eryk
