----> error: L6236E: No section matches selector - no section to be FIRST/LAST.
1. Someone please tell me what is meant by scatter file. I don't think I have problem with my code because it is a simple one, my code compiled successfully when I compiled it without selecting memory layout. After that it shows following error: L6236E: No section matches selector - no section to be FIRST/LAST.
----> No LPC2129 in Keil Version 5
2. I am using lpc2129 I could not find the details of it in Keil Version 5.
Have you worked through Keils tutorials for how to create new projects?
You have no startup code - which should be flagged as "FIRST" to make sure it gets stored at the location where the processor will jump after power-on.
Thank you sir, I will refer it and get back to you.
Thank You Mr.Per Westermark, Now its working fine after adding the Start up file
Your welcome. It's always nice to get that initial program up and running :)
