Hello All,
Total assembly noob here, apologies in advance if my problem is trivial. I am working on a project that requires making an adjustment to code written in '91. The MCU is an OKI/LAPIS 80C31F. I believe the original assembler was a 2500AD. I am currently trying to assemble using the A51. I have had to make a handful of adjustments to the code in order to have the A51 assemble, but I am hung up on one translation.
MOV R5,#<M_PPU_DFLT MOV R6,#>M_PPU_DFLT . . . MOV R6,#<20000 MOV R7,#>20000
The original author used a ton of these instructions, they are always MOV Rn,#immediate. Sometimes the #immediate is a symbol, other times it is a decimal number. But, they are always preceded by the '<' or '>' operator.
The assembler kicks back a syntax error for these statements. What can I do to alter this code in a way that the A51 will except it without losing the functionality of the instruction?
Thank you for your help.
It's basically related to this thread: http://www.keil.com/forum/10440/how-to-use-low-or-high-in-a51/
Perfect, thank you. The LOW and HIGH are exactly what I was missing. Problem solved.
